Icebreaker build materials
It looks like you will have to do a slightly different rudder setup as the pivot point could clash with the frame.
You will probably have to cut some of the wood away near the frame so that you could fit the rudder linkage.
I think i know were you went wrong.
You say you used a mouse for sanding down!
Maybe you should of used something rougher to start with like a Rat LOL!!
You are certainly having a rough time with this hull.
In the past i have also had boats that did not want to be built so i know what you are going through.
The only advice i can offer at the moment is keep trying, just do a little bit at a time and when you are happy with that then do another little bit and so on and soon the worst bit will be over and you can start on the best bits.
Remember if i can help just shout.
strips from SLEC. I don't look at myself as a modeller just a reworker. Well I can polish a turd and make it look good. Great to see you back.
On my Eastwind build I use blocks of Bass wood rather than Balsa. Reasons were, a firmer backing, less likely to sand too much away, holds onto resin better than balsa( balsa absorbs it so much that the surface loses volume and the glass tears away easily). I ordered mine from Midwest: https://midwestproducts.com/pages/wood
As for glass cloth, I used a fine, weave, I think around 5 oz. Easy to fill the texture with two coats of resin.
Piaciuto da
Caricamento…
