Sail and mast rigging
Follower (3)
I am following this log and it would be interesting to see some photos of how you are getting over this problem along with the text, as it will also benefit others that might have the same sort of problem.
Cheers Jon.
You could use thin rope or even string. Just use some small pieces of ply or thick card under the rope to protect the gel coat on the hull. It should not need a great deal of force as you will be putting it in the same shape as it was in the mould. I should mention that at the bow and stern the curvature will require the stringer to bend. If you cut 1/2 way thro the stringer at say every 1/4" it will then be easier to bend to shape. Just soak the cuts and stringer in glue and clamp to the hull and adjust the inside spacers to give the correct shape. Do look down the length of the hull on each side and make sure there are no obvious dips or bulges. A one meter rule is useful but there may be a flare on the plan so make sure it looks right as any mistakes will need repairing or you will have to look at them forever☹️.
You may need to raise the height of the prop shaft so you have room to fit a lower mount for the rudder. You can repair any holes with P34 or similar.
I have just released the keels from the mould so if the weather is not too cold I will join the two together and when hardened I can smooth off and they will be ready to send, hopfully next week. PM me your name and address please
Cheers Jon
It is your choice but if you do that the plan will no longer match the hull. Meaning any measurements you make would need to be adjusted. I suggest you pull the hull to match the dimensions on the plan. Normally you would run and glue a stringer (1/4" basswood etc) at deck level all round the inside of the hull. You then use clamps to hold in position (I use straps wrapped round the hull and scraps of wood between the stringers). When set you can fit your deck beams by cutting a slot at each end to accomodate the stringers. It is quite common for fibreglass mouldings to lose their shape when out of the mould and that is an advantage of making your own as you can put the hull back in the mould and fit the stringers and beams so it follows the mould.
You are doing well but do take your time as any errors now will cause you grief later on.
I believe the bigger prop would be a better choice.
Glad you like the pics.
Just had a quick look for video of Brian Clewes' Amelie Rose but not found any so far. I am posting some pics that may interest you in the meantime
I see you have discovered fibreglass is sometimes not constant thickness. I have laid up many hulls and even taking the greatest care the end result is often not uniform. For scale model use this is still structurally sound but for a high speed racing type the materials and resin used are carefully chosen for max strength and least weight.
If you are adding more fibreglass do it on the inside to avoid damager to the gel coat. Quite common for voids and thin spots where the two hull moulds join.
The prop on my Cariad was 40mm but it was in free water at the side of the hull. You will need a prop large enough to overlap your stern post as per the Amelie Rose pic. I suspect the prop on your model was for manouvering whilst docking in harbour. If you want this to help when on the water you may need something a bit larger than you have shown. You may need to raise the prop a centimetre or so higher to allow for the size.
I do have some video of our yachts sailing and I will try and find one of Amelie Rose.
Beautiful and sunny here today, but cold light wind. I have got the fibreglass in the moulds and its curing in the sunshine. When set I can join the two halves together with more fibreglass then it should be ready to post.
Cheers Jon.
I am making your keel but the weather is not helping. To-day seem ok though so hopefully I can get the fibreglass to set.
Brian had his Amelia Rose at the lake yesterday and I took some close ups of his central prop and also the keel for your info.
Good to see you are progressing with the build. I hope you have checked the hull moulding to the plans as there will have been some movement in the casting once out of the mould. I run a piece of thin cord from stem to stern at the mid point then measure every couple of inches from the cord to each side. Do the same with the plan then you can adjust the hull to the correct symetrical size. It's not unknown for the plans to be inaccurate so best to identify any anomalies early on, it will save you some grief further down the line. I usually make any parts out of card (cereal packets etc) and fit before cutting any wood or plasticard.
Looking forward to your next update
Kindest regards
Jon
Any lead is suitable but be wary of any that has bitumen or tar coated on it. I also have a deal with my local tyre fitter to supply me with his scrap wheel balance weights. They come with the metal attachment tags and I just throw them in an old painters bucket with a handle. I then put on the camping stove and melt the lead. When melted I pour into some sand with shapes in to collect the lead. Make sure it is dry as any water will turn to steam and cause a scald. I always use my safety glasses, welding gloves, stout shoes and a leather apron to protect myself. Much quicker than trying to seperate the metal from the lead and I then have a selection of different sizes of lead. Make sure it has cooled before you try to handle the lead, it stays very hot for longer than you think.
I use layup resin which is thinner than the Isopon in the car shops. My local supplier is
http://www.resin-supplies.co.uk/
and you need Polyester layup resin and hardener. 1 Litre will be more than sufficient. You can also get Acetone and Iso Propyl Alcohol to clean brushes and tools. I also wear Latex Gloves. You should have a local supplier in your area but this shows you what you require.
No do not fill above the lead so you can provide a seal between the keel and hull bottom.
The bolt need to be aft of the mast mounting, in my case at the bottom of the hull. If you look at the pics I have shard on dropbox you will see the bolt is about 1/3 from the front of the keel and fits as close to the bottom as possible, not forgetting the lock plate and nuts to prevent rotation. The keel front is mounted just ahead of the mast and adjusted so that the mounting bolt is aligned with the block of wood inside the hull. You could mount the block inside the hull with a hole drilled then mark the hull inside and drill a small pilot hole thro the hull. If it looks ok glue the block inside and open the hole to size. You can then adjust the bolts position in the keel and set its position with some lead and resin. I used a jig to hold the keel vertical and horizontal then put the boat over the keel with the bolt in the block of wood and adjusted the hull so it was also horizontal. Keep adding more lead and resin and checking the level to keep everything square. Stop when you have added all the lead or you are within an inch of the top of the keel. It may be more on your model as this was the depth of my hull keel which need to fit in the top of the keel I am making for you. You will see that there are flanges on the keel to support the weight to your hull. Once the resin has set in the keel (24+hours depending on temperature) you can make good the fit to the hull using P34 filler or similar. I covered my hull along the join are with a several sheets of cling film, then put the filler in the keel and mounted it to the upturned hull using the bolt to pull tight. Make sure the filler makes a smooth joint all round to the clingfilm and leave to set for some time as it will not set as quick as when uncovered. I had to give the bolt a very gentle tap to free the keel. You van then remove the excess cling film, I left what was on the keel and tidy up the edges to fit the boat hull. You may need to use more filler to make good. I sealed the hole in the block of wood with Polyurethane varnish but sanding sealer or similar would work. Finally I made a conical nylon plug for the top of the block to prevent water ingress. I also added some silicon sealant to the bottom of the hull where the rod attaches.
Glad to hear you have your motor. As you are fitting the prop behind the rudder you will need a fairly large 3 bladed brass prop but no bigger than the motor say 45mm.
I will let you know when I have the mould for the keel.
Cheers Jon
I use cut up pieces of scrap sheet lead but shot would work. Just make sure it fits inside the keel and cut smaller if it doesn't. As I mentioned I put a bag, keel, motor,ESC and winches inside the hull and added lead to reach the waterline whilst the hull was in the test tank. I then removed some of the lead to allow for the resin to be added. Probably best to just add enough to bring to the base of the waterline as you can always add a little more inside the keel to correct later. In fact it is best to have the model riding slightly high until you have trimmed for sailing. I used threaded 1/4" rod for the bolt. Make a small plate to fit in the keel low down and bolt this to the rod eith two nuts, this will stop the rod from turning when you tighten the bolt inside the hull. Leave the rod a good foot above the keel until you have added the block of wood with a hole and mounted the keel and added any washers and sealers below the nut. You can then cut to size when you are happy.
Cheers Jon.
No problem if it's not raining on Monday, Brian will take the mould to our sailing site and I will then fabricate the shell. Hopefully the weather will remain mild as the resin won't set if it's too cold. I will let you know what the postage cost is after I have posted. Component shop, Ian and Natasha, are running the Blackpool Show this weekend with help from local clubs. 😁👍
Cheers Dave much appreciated.
Regarding the external ballast this is a fibreglass shell made by a friend. I can borrow his master and make you a copy if you wish. It is fairly light so will post OK.
Fitting the prop as you suggest will work better with some modification to the rudder.
For a 555 motor try
https://www.componentshop.co.uk/motors/dc-brushed-motors.html
They have them in stock.
I see from other posts you were supplied with an 800 motor and as others have indicated this is unsuitable as is the 400 size. 540 motors would work but the 555 is more suitable for your model as it will draw less current and provide more tork at low revs.
cheers Jon
I still think you would find the 540 or 545 motor a good match for your boat.
Kindest regards
Jon
Looking on Sarik site I'm assuming it's the 1/12th scale one, that has a 20 inch Hull. If that's right then the 800 motor is far too big, a 545 would be plenty for such a small model.
My large motor lanch Caroline is 56 inches, and weighing in at 13 to fourteen kilos is overpowered with an 800 motor, and my 4ft tug only uses a 540 motor and is really efficient.
Your boat isn't a speed boat, so some trial runs with the smaller motor will prove you don't need to waste money on a large motor.
Regards Jon
Cheers Jon
For a single prop the rotation is not important and either will be OK. You can swop the wires to the motor or change at the Tx to ensure the correct rotation.
The motor I used was a 555 brushed as this has good tork at low revs. You will need a mount and a HuKo type coupling to connect the motor to the propshaft. To control the motor you will need a 15 amp ESC and a battery for the motor and sail winches. Many ESCs have a built in BEC circuit but I would recommend using a separate UBEC as this will have sufficient output power for your requirements. If you are using a UBEC you need to disconnect the red wire from the ESC to the receiver and plug the UBEC into the receiver battery connector. My shaft was about 7" but chosen and cut to suit the hull, motor and prop size so may be different to what you require. The prop sits to the left side of the hull looking from the stern.
I do have a folder on my Dropbox account that contains lots of pics and the Model Boats article on building the Cariad. If you send me a private message and share your e-mail address I will send you a link to share the files. You don't have to join but will be able to look on-line and download any that are of interest.
Cheers Jon
Building stand for the Hull first then start the model build, I have started a build Blog so here we go.
As long as it is covered with fibreglass and resin and there are no holes it should be fine. You are building a model and the structural strength of the fibreglass hull will be more than adequate for the task. There may be some residual flashing along the keel where the moulds joined but you can carefully sand this away with some wet and dry fine sanding sheet on a flat sanding block. You will need to start by measuring the hull to the plan and making sure it follows the correct lines as there may have been some variance during the layup process. You will need a wooden support all round the inside of the hull at deck level and you can place cross struts to ensure correct sizes. I used flat tape wrapped round the hull to hold the inside formers whist the glue dried. You will need to roughen the inside of the hull where you are gluing to remove any residual release agent. Iso Propyl alcohol (IPA) is also good for cleaning all surfaces before gluing Use a good quality two part epoxy and not one of the cheap pound shop versions. Stablitz Express was my favourite when building model planes but you can now buy UHU PLUS ACRYLIT EXPRESS EPOXY which is ok. I built a building stand first as this will help with the build and establishing a datum line.
Just a thought, as you are now starting the build perhaps now might be a good time to start a build blog so others can benefit from the advice you will receive and seeing your progress.
Now the exciting part starts. Enjoy.
Cheers Jon
Please do copy the build blogs. You can also print them from the site and this may be useful when you are away from a PC/Tablet etc.
If you look at
https://model-planes.com/blogs/7821
About the tenth article from the start is one titled Ballast and Planking repair where you can see a pic of the keel with supporting steel bolt connector together with a pic in side the hull showing the nut holding the bolt in place. This is mounted on a large block of timber just forrard of the main winch servo. This need to be higher than the waterline and I use a sealant plug under the nut to stop any water ingress.
The keel is a fibreglass moulding made by one of my club members and is used in several scale type sailing boats. We fill the inside with lead to bring the model to waterline then put the bolt in the correct position for the hull mounting using a template. The keel is then filled with chopped up lead and casting (layup) resin. When set I finish off the top to match the keel with plastic padding and finally silicon sealant using a sheet of polythene between the keel and hull. After a couple of days warm weather you can separate and trim to shape.
Hope this is what you required but please ask if you need help. There are many modellers on this site and new ideas and techniques are something from which we can all benefit.
Jon
Not sure if you have looked at the Build blogs for the Cariad I was referring to.
https://model-planes.com/blogs/8723
https://model-planes.com/blogs/20723
Hope your hull and plan arrive as promised.
Jon.
This is where Im` up to :- https://www.youtube.com/channel/UCdsv9h3gn3DX2jwDgB4GQ0Q
Cheers / Phil⛵
Piaciuto da
Caricamento…
