STRINGERS
STRINGERS
STRINGERS
Cheers, Nerys
STRINGERS
So make that a pisco sour or Cuba libre for me 😋😋
STRINGERS
STRINGERS
Understandable, both have four letters and sound a bit fruity!😋
STRINGERS
STRINGERS
Commonly called Lime in UK and Ireland and Linden in most of continental Europe.
Like the famous Berlin avenue; Unter den Linden (Under the limes).
Nothing to do with the fruit trees😉
STRINGERS
Even earlier kit makers such as HMM and notable model boat designers such as Vic Smeed specify obechie for use as stringers in their designs.
I have build most of these kits since the early 60's, and this has covered a range of sizes from small (patrol launch) to large (SeaQueen and Rapier etc).
None of the models that I have ever built have needed the stringers to be soaked (or even wetted) to comply with the shape of the hull (but it is always an option), so it would seem to me (at least) to be a good choice of wood for use as stringers in model boats.
STRINGERS
Cheers Jon
STRINGERS
I've got a thing about bass, I like it's appearance and working with it.
Cheers, Nerys
STRINGERS
I double the bulkhead thickness at the top of the contact area over the bulkhead so that when I join the second length of stringer, it has a nice platform to sit on to support and cover the joint.
The second layer of stringers are joined in a different place so the joint is strong and durable.
This overcomes the need to buy over-size lengths of wood that may be hard to find - and helps to keep the cost down too!
STRINGERS
For example - if the plan calls for 1/4" x 1/4" stringers, then I would fit the first stringer using 1/4" x 1/8" obechie (or the metric equivalents!) and then fit a second layer of 1/4"x 1/8" afterwards to build up to the same thickness .
I have also found this to give a better 'wrap" that follows the contours of the plan better too..
This idea came from my first ever model boat building experience with an Aerokits Swordsman sometime in the 1960's, and it has held me in good stead ever since.
Piaciuto da
Caricamento…
