Outboard drives
Outboard drives
Outboard drives
Regards, Gary.
Outboard drives
Outboard drives
I started 2 years ago and due to the big C (prostate) i have had to put the car on hold. roll on spring I can start on her again.
Outboard drives
Outboard drives
Outboard drives
Outboard drives
Outboard drives
Outboard drives
That stern-drive is the right size for that scale.
Outboard drives
Outboard drives
The transom is very curved on the H31 and would need flattening off.
Outboard drives
Very true Rick👍
BUT (there's always a BUT!😉)
"If you don't have a dream how you gonna have a dream come true?"
Great film South Pacific.😀
Cheers, and Goodnight from Munich,
Doug 😎😴💤💤
Outboard drives
Rick
Outboard drives
You have no reason to be humbled, your 'magniferous' Typhoon alone proves that.
Looking forward to your future contributions.
Thank you but I'm not the Master.
Check out what Graham93, Robbob, mturpin, Martin 555, jbkiwi, and our steam engineers amongst many others have been up to. I'm just not too bad at finding things quickly😁
All the best, Doug 😎
As German model boaters say-
Wishing you always a finger of water under your keel 🤞
Outboard drives
I am truly humbled by the talent and expertise exhibited on this Site!
I feel very fortunate to be part of it!!
Outboard drives
Tell me about it Rick 🙄
A 47" hull should have bags of room aft for the two drives, but at US220 a shout that's a costly venture! On the other hand I have to admit I've been known to fork out €1000+ for a kit, and still needed some refinement extras🤔. But, When you find something you've wanted for decades ...!
Looking forward to future developments Rick👍
Outboard drives
Rick
Outboard drives
They couldn't find a TFI, at least not one relevant to model boats, but did come up with the TFL. Pricy though. Must be made by Rolls Royce 😁
Outboard drives
Is this what you have in mind?
https://www.offshoreelectrics.com/proddetail.php?prod=tfl-b42515
If so the motor itself is actually inboard, but will require some hacking about of the aft end of the Huntsman to get it in as they appear to mount on the transom, rather than hanging under the hull like a traditional shaft drive. And won't you need two of them? Rather pricy at 220 bucks a go 🤑🤑🤑
I'm not a Fairey aficionado by any means but that's what occurs to me looking at the drive system data. Fair bit of Kit-bashing required! Quite a challenge.
Bon chance mon ami🤞
Outboard drives
If you are looking for an outboard, Mack Products has two outboard motors MP 4020 Brushless or 4025 Series which has 4 options.
http://mackproductsrc.com/power%20units%20-%20q.htm
Hope this is of some help.
Good Luck!
Trev
Outboard drives
What Huntsman are you thinking of, 28 or 31?
But whichever I'd say probably not. Reason being is that the motor doesn't look very tall and seems to be designed for speed/raceboats.
You'd need to have a cut out well down the transom to get the prop at the right height and being a deep vee hull the motor would probably be in the water at lower speeds. Also it would need to have a well and false transom so that the boat doesn't get swamped when reversing.
So quite a bit of modification would be required. Nearly everything is possible though!
What are the dimensions of the outboard?
Or am I misunderstanding and it's the stern drive version? If so, then it could be installed in a Huntsman without too much trouble. Looks a very nice unit. I'm currently building a Huntress with a Bauer-Modelle stern-drive which isn't a bad unit but it's plastic. If the TFL unit had been available I would have bought one of those!
Outboard drives
Any help appreciated.
Rick
Piaciuto da
Caricamento…
