36 inch Thames Police Launch.
Follower (4)
- robbobSilver
- mturpin013Bronze
- NickthesteamSilver
Good to see that you are making a start especially after a bout of illnesses!
You can bet you'll find your roll of soft iron wire while you're looking for something else. Such is the 'Law of Sod' 😉
Rob.
Anyway, first job, the rudder, fabricated from 1/16" brass sheet and 5/32 brass rod. Once cut out, the two slots were milled 2mm from the edge, leaving enough space for a good strong joint. Next a 1/16" slot the length of the rudder blank was milled into the 5/32" rod, due to my goggy eyesight it is slightly off center but not enough to make any difference. I can't silver solder them together yet as I need some soft iron wire to bind them together whilst being soldered. For those that didn't know silver solder will not bond to soft iron wire. I have a roll somewhere but can't find it, so Amazon to the rescue!
I really like the what you're doing with the keel/prop redesign, it will look really good and should work just fine.
You may find that reducing the propshaft angle will mean you have to move the motor location further into the cabin very slightly but that's of little consequence.
Rob.
Should be a simple job to fabricate from some brass tube and sheet, silver soldered together.
good look with the build
Michael
The plans for the kit I built were also in two parts so they're no different. However they are good quality prints with no geometric distortions so they are easy to align and tape together, and you won't be building off the plan anyway. The CNC and laser cutting is extremely accurate so the parts fit well with little or no 'fettling'.
Robbob.
The VMW kit is a great choice for your latest project and is very good value as mturpin013 has already said.
When I built mine I did some extensive research on the history of the boats, found some good pictures and also a few videos on BritishPathe of the boat in action which I found very helpful for detail.
Here are some links to the videos:
https://www.britishpathe.com/video/river-police-rescue/query/river+police+rescue
https://www.britishpathe.com/video/river-police-1/query/river+police
https://www.britishpathe.com/video/river-police-boat/query/river+police+boat
https://www.britishpathe.com/video/river-pilot/query/river+police+boat
I'll also be following your blog with great interest 👍😀.
Check my blog too 😀
https://model-boats.com/blogs/47891?sort=ASC
Robbob.
If you need any help have a look ay my blog you may find some tips useful before you start the build. but don't hesitate to ask if you need any help
https://model-boats.com/blogs/78377
Piaciuto da
Caricamento…
