Bilge pump ?
Iniziato da steve mull
5 replies 8 mi piaces Ultima attività: 4 anni fa
Bilge pump ?
I would like to add to my question about Bilge pumps. that in my RAF style launch, the water ingress problem has stopped
One, as i filled the mainshaft tube with vaselaine, but probably more so, that i sloshed clear varnish around the inside of the hull in all compartments, let it dry, and did the same again,
I now as of today, have NO water ingress at all,
steve
Piaciuto da GregHiltz
Bilge pump ?
I used a hydro switch and a 3v-6v pump at 3v. Mounted the switch 1/4" above the pump pickup. It comes on when the switch gets under water and goes off when the water is out. So far has worked perfectly.
Piaciuto da Len1
Bilge pump ?
Thanks for the replies,
I did think about a windscreen washer pump, and am running a 3s lipo,. so 12v on tap,but overnight in my dreams (weird ones) i used a large syringe when the boat was back in port
Steve
Bilge pump ?
Hi, Over the years, I have used numerous setups for bilge pumps and water ingress alarms/switches for members in our club, and ultimately to sell.
I had a friend years ago who was quite adept at devising speciality circuits. He made a water sensor alarm which was only size of a large Postage Stamp. He made approx. 20 units before he died, and I still have one left.
I have another modeli g friend who has found a similar unit on- line which can be wired to a small pump and alarm. I still do have a couple Robbe water pumps in stock. And it is also possible to incorporate a windscreen washer pump into the bilge to suck out the evil water.
Piaciuto da Len1 and RonH
Bilge pump ?
Hi all
Does any one fit a bilge pump, in their models?, as i seem to be able to get a nice amount of water, but no fish after a 15min blast round the lake, i say nice amount of water, but more like 1/2 a coffee cup worth, but its a pig to get out, so i might have to fit a drain hole, as in dummy exhausts to let it out
Piaciuto da RonH and pressonreguardless and
