Prop question
Iniziato da quattroo
4 replies 6 mi piaces Ultima attività: 4 anni fa
Prop question
I would try speaking to Simon at PropShop and ask his advice. Looking at your video the present prop is not correct for that model. a 35 or 40 mm 3 blade brass prop would give much better scale speed for your Huntsman.
Piaciuto da quattroo
Prop question
Yes my bad it's 42" version I'm running 4260 /60 500kv brushless tornado thumper outrunner motor direct drive 80amp esc and 6s 22.5 volt lipo 50mm xprop (plastic)
Prop question
Just one point that's needed to offer advice we need more information.
Motor? Esc? Batteries? Hull length?
I have vintage 1965 34" huntsman
Running on 12v7ah sla, Johnson 600, mtronics 25 marine esc, prop 3 blade brass 40mm and at 3/4 throttle it flies any more throttle it is too uncontrollable.
Piaciuto da dave976 and Madwelshman and
Prop question
Hi all I've managed to get the Slec Huntsman out for a run (vid to follow )
Now I'm running a m4 50mm x prop pos to big I'm wondering your thoughts is there a brass 45-40mm brass x prop out there on m4 m5 thread or for the prop gurus what would be a three blade equivalent as the speed is spot on
Piaciuto da Madwelshman and Colin H
