Blast from my past
Follower (2)
Blast from my past
Blast from my past
Scott
Scotland
Blast from my past
At least now it will be a far more unusual model that when you were 16!
It should also go well as standard - and you could then make it go far faster than the designer ever predicted by fitting a small brushless motor for more thrills and spills.
With best wishes. John. 😀😮😀
Blast from my past
So I have given it a mild update ditching the 27mhz and fitted 2.4ghz. 30amp esc over the standard 15amp. Have changed the rudder for something completely different and added a new prop. Have had to remove a few stickers as they where lifting and become brittle. The included Futaba S3003 servo doesn't show signs of life at all which is odd as they are bulletproof though I popped in another standard Servo.
Bath test completed and time for a maiden tomorrow! Will post a wee video from the moment it's placed in the water. Hopefully a nice little cruiser. Will be changing the colour after the maiden along with the motor and a surface piercing prop though remaining brushed
Wish I had opened her up years ago though life changed a lot when I turned 16 and I had placed this in my parents cellar and forgotten about it along with several other boats and aircraft. Still she's out now and ready to finally touch water
Scott
Scotland
Piaciuto da
Caricamento…
