Question about Schottel drives
Iniziato da Westwind
9 replies 17 mi piaces Ultima attività: 4 anni fa
If the Z-Drives are the 70BM-Z tooth belted, they look pretty durable. Interesting setup with the belt drive for both the steering and propeller!
Usually, the z-drives are independently controlled to give the vessel amazing maneuvering. Years ago I talked to the captain of the Arne Christiansen towboat (photo attached) and we discussed that. To implement the 360 degree forward only the transmitter setup is quite unique, operating like the real boat, each mounted in a rotating knob with the speed control in the middle. You can see the z-drive controls, one on either side of the captain's consoles (interior photo).
Anyway, good luck on the build and I look forward to seeing progress reports and photos!
Piaciuto da hermank and Westwind
Don't know why the link will not work, maybe cause I am on my phone? But yes it's the jonny and the drives are the 70BM-Z
Same here Lew☹️
But I suspect it could be this model, the harbour tug 'Jonny'.
Cheers, Doug
https://www.bauer-modelle.com/epages/Bauer_Uwe46269592.sf/en_GB/?ViewObjectPath=%2FShops%2FBauer_Uwe46269592%2FProducts%2F303000#tab-product-attribute-MyOwnTab
https://www.bauer-modelle.com/epages/Bauer_Uwe46269592.sf/en_GB/?ObjectPath=/Shops/Bauer_Uwe46269592/Categories/%22Schiffsantriebe%2C%20Spezial-%20und%20Wellenantriebe%22/%22Schottel%2C%20Z-Antriebe%22/Kunststoff
I get an error message on the link: "The page requested is not available."
Piaciuto da RNinMunich
Thanks for the input. Here is the boat I ordered and the drives for it.
I will be using my x10s radio for it. The plan for now Is to have both drives controlled from the right stick. The servo I got for them should act like a sail servo so an input to the right will rotate the drives to the right until I put the stick back in neutral then the drive should stay in position until the stick moves again. Both throttles will be on the left stick with no reverse. That's the theory for now, have to see how it plays out in practice.
https://www.bauer-modelle.com/epages/Bauer_Uwe46269592.mobile/en_GB/?ObjectPath=/Shops/Bauer_Uwe46269592/Prod
Piaciuto da hermank
This is something I looked into several years ago. I made a complete set of 1/32 scale drawings for the MV Arne Christansen, a US towboat. I bought a pair of Graupner z-drives for it but never started the build.
Operation on the real boat, the props rotate in only one direction as they are designed for efficiency. To run in reverse the drive is rotated 180.
Also note that the z-drives (schottles) are independent from each other, both steering and speed.
In using the model Z-drives, I guess it depends on who/how they are made. Graupner is specific on reversing and steering change while the propeller is rotating. Power off while doing that.
Now, about the transmitter for 360 degree rotation... complicated!!!
Florida, USA 🇺🇸
Piaciuto da Westwind and hermank
Here ya go Westwind, bon chance🤞
https://www.schottel.de/en/home
https://www.google.com/search?client=firefox-b-d&q=Model+Schottel+drive&tbm=isch&source=univ&fir=cWyuzZxOSvcIGM%252CMPVr43aMOu4WdM%252C_%253BScvQNHCDEH_4AM%252CbCgQk8CDeSjEEM%252C_%253B3-IRCZkKEltEuM%252CCtfAMX6QCfq8jM%252C_%253BP_hiWH_YYo9B9M%252CFzr3mz94pYB7WM%252C_%253BAqmEstFk2K-O0M%252CSUfY1fG4jvjv0M%252C_%253BwOEt8mbgy1RBpM%252Cd0jL9HZ1wnQJvM%252C_%253B-LJGP8R3JiNd2M%252CSUfY1fG4jvjv0M%252C_%253Bw6GuKisHvjL5vM%252CpLCG4IxQ78lAyM%252C_%253B0dwlidwvjIWl_M%252Cl9ssTRYsspAeKM%252C_%253BISDkBDzUwrY6RM%252CSUfY1fG4jvjv0M%252C_&usg=AI4_-kQ39uWRbrGM2wIJKsx5_jP3GtLsuw&sa=X&ved=2ahUKEwinkqfzisX-AhUxRfEDHZOtAFkQjJkEegQIIxAC&biw=1888&bih=908&dpr=1.02
https://www.cornwallmodelboats.co.uk/acatalog/Schottel_Drives.html
https://www.cornwallmodelboats.co.uk/acatalog/CEM050.html#SID=1808
https://en.wikipedia.org/wiki/Schottel_(company)#
Piaciuto da Westwind and hermank and
Thanks Dave, I was not sure if the motors rotation could be reversed. I'll have to set my radio functions to rotate the drive fully when revese is needed. Steering this boat is gonna take some getting used too.
Piaciuto da hermank and dave976 and
Hi Westwind
I suggest you search Schottel drives on Google for a full description of what they are and how they work.
Basically they consist of a motor in the hull driving a shaft below the hull to the prop at right angles to the shaft in a tube which can rotate through 360deg which will propel the vessel in any direction. Prop rotation is always in the same direction and the whole driven part is rotated by a servo etc.
There are (or used to be) commercial items available and they work very well.
Piaciuto da Colin H and Westwind
I'm planning in building a tug using 2 Schottel drives. For those using them, how do you get the ship to back up? I'm thinking either run the props backwards like a normal drive system, but I'm worried the strain might strip the gears, or I could attempt to rig it so that I move a switch and the drives pivot 180 degrees in the opposite directions so as to keep the side thrust about the same. Any thoughts?
