Finishing Balsa boat
Here is a article from Model Boats. hope that it helps
obtain a pair of fine denier ladies tights. Cut off one leg, cut off the foot and push the hull through. Paint or varnish one coat and allow to dry. sand off at deck level. The hull can then be finished with paint and varnish until the weave disappears. Lightly sand and finish as with any other wood.
The only drawback with this method is when the model has a deep keep. In this case it is best to fix an obeche keel externally, after the hull has been finished, as above.
Fred
I use this also when applying the light weight fibreglass cloth. Works well, virtually no odour.
I only glass the outside of the hull. Deck, and depending upon the vessel, say a sailboat , the fibreglass is placed on the outside of the deck structures which gives a water tight seal, generally 😄
RB
In the day's when Nelson had both eye's, I used to use the girlfriends old stockings and dope, it worked well then and I still use it today ( not the girlfriends stockings, the wife would not like it)
You pull the stocking/tights over the hull from the stern to the bow until it is tight, tie off the the stockings/tights then apply the dope to the hull "DO THIS OUT DOORS" when dry remove any waste. apply another coat of dope then when dry you can then paint the hull.
Fred
Piaciuto da
Caricamento…
