Fitting an alternate set of sails
Follower (5)
- roycvBronze
I decided to do things in reverse and fit the mast and boom to suit the sail. I started to progress and got the upper part of the sail a bit flatter. Brought her back in and found if I pulled the sail down towards the boom rather than let her run free the sail would start to flatten out. Also tightening up the lower part of the sail to the mast looked a good thing to try. So a bit of lashing this afternoon. I shall run a 'rope' through the lower seam and try and spread the effect of the lashing along the sail boom.
The jib was not so good as I had tried fitting a flexible wire into the bottom seam but this had a separate life of its own and distorted the sail especially when the jib was hauled in. I had a fore stay running through the forward edge and a separate sail haul. I will abandon this and go back to a jib boom which will need making.
Progress of a sort but curing the faults is a first step. Who ever said its just a rag and stick job!
This was starting to get a bit tricky as I had to remove the winch drum to reduce the tension. I set up the winch assembly again and tied on the sail sheets and gently replaced it into the yacht. I made the hatch just wide enough to fit my arm inside and locating the guide pin into its slot was a feeling job, but all screwed into place now.
The RC battery an eneloop one failed to respond to my intelligent charger so I started it off with an SLA charger and after 10 minutes I got a response and then reconnected it to the intellligent one where it took a full charge. This enabled me to set the position of the winch drum on the winch servo. I will have to be careful as the 'sails in' works fine but there is more travel than needed at sails out.
That's all for now, busy in the morning but will do a set up of the sail suite in the afternoon.
The yacht is from an old Graupner kit , there is some detail in my harbour, the part built model was a gift, but I have the plans as well. I thought it would be nice to have an interchangeable set of sails. As I type this is still an on-going project.
But testing the yacht for its functions, the rudder worked but Oh dear the sails made noises deep within but no sign of movement from without! On opening up I tried to remember how it all worked, we are talking 17 years ago when I completed her and my memory failed me. Eventually after internal inspection with a good torch I could see I would have to remove the winch system.
I could then see that the elastic had broken!
It was also necessary to fit another location to take the additional sail. This is a filed down section of old brass curtain rail from about 100 years ago, Needed a few holes drilled and it was screwed in place.
The sail set is being constructed around an old mast probably pre-dating the kit which had a ready fitted jack-line, but it was not long enough so the lower part had another 12 inches or so scarfed in, but my woodwork is not so good these days and so I painted over the handiwork, but it is straight and true.
When planning what to do I realised I did not have any small eye hooks to allow for the several bowsies on the mast. A rather long search on the Internet led me to dress making fittings and I ordered 100 for the paltry sum of £1.87 including postage and they work a charm!
Also I used to make my own bowsies but time is a bit more valuable to me now and I ordered some from one of the almost ready to sail yacht model suppliers Volantex I think, 20 of them, and over half gone already. As these were black I also decided that new brass fittings which I made would be left in black which is also the colour of the etching paint.
Now a 4 foot long mast 1/2. inch diameter and a bit tapered bends a bit with the wind. Bending moment is about upper middle. So with the mast stepped on the keel and although adjustable it needs a semi-clamp as it goes through the superstructure.
This moves the bending moment up considerably. Why bother? Well the main sail is closely located to the rear of the mast and likes to be in just 2 dimensions, introduce a 3rd. dimension and it has to fold a bit to accomodate. This sail set had sail battens to deal with this. Inspection showed they had suffered over time and so the broken ones were fished out and new strips of white PVC plastic were cut and inserted.
The deck is separately planked and joggled into the king plank as the hull when I received had printed deck planks which had faded to barely discernable.
More as the job proceedsl.
Piaciuto da
Caricamento…
