Your thoughts please.
Follower (8)
- NickthesteamSilver
- jumpuglyGold
- chugalone100Silver
Thank you all for your valid and interesting replies most of which have my notions in mind.
I think I shall do some but certainly not all and lightly weather the surrounding brass.
As always it’s good to hear your thoughts.
Bill👍
I'd go for some and some, as I know from my own 1/72 destroyer (HMS Hotspur H01) what a chore that can be. Got it all ahead of me again after re-skinning the hull to strengthen it☹️
I'd leave the forecastle portholes dogged down, in case of heavy seas.🌪️🤔
Open some of them midships and stern and fit subdued lighting behind them. E.g. yellowish.
In the wheel/chart-house perhaps orange/red?
4 function RC switches (e.g Krick or Component Shop/Action Electronics) could be used to animate them and simulate life on board.
Weather to taste - before you fit the lenses/clear resin😉
My two-penneth for what it's worth
Pic shows the portholes on the forward superstructure, stb side, of my Hotspur.
Made 30+ years ago using brass belt eyelets and a few drops of clear epoxy.
Due for replacement with proper flanged frames,
My second thought is that they should look pretty much alike. If the frames differ significantly, you will notice it and it you are like me, it will haunt you.😀
Of course since it will be an r/c you have to have them sealed.
You could overlay them on top of the existing ones or smoothly sand them off until you could glue the brass portholes flat to the hull.
After that is just a matter to add an aqua or greenish drop of paint inside each and let that dry and add a few drops of epoxy to represent glass.
And I wound’t add any weathering on them but if you must, do it slightly.
We could easily go wild with the weathering but it wouldn’t look good on a vessel so small, so the less weathering the more authentic it will be.
This is my humble opinion but you will receive many other to choose from.😎
As you are doing a refit then it would seem sensible to remove all that is there and replace with your bits. Looking at the originals the detail is not that good so removing all and tidying up the surrounding area and replacing with new would be worthwhile and probably in keeping with the rest of you restoration. They do cover a large area so will be prominent on the finished model. You will I suspect weather the finished result. Look forward to seeing how you proceed
I am at this time carrying out a refit blog on HMS Verulam which some are following 👍👍.
Having gone through the boats shed box of bits I find I have enough scale portholes to do the model.
I have a quandary…YES or NO as to if I do them.
If I do them,shall I just do some and leave the remainder with deadlights closed.
OR
Do I do them all and suitably weather around them.
I have my thoughts,but thought I would throw it open.
I attach a couple of pictures for thought.
Sensible answers on a post card please.
Bill.
Piaciuto da
Caricamento…
