Advice needed
Iniziato da Damon
10 replies 2 mi piaces 0 follower Ultima attività: 13 anni fa
Advice needed
Sorry to be a Royal Pain in the Bottom 🔨 but the dilemma has been sorted out. Now its just a matter of wiring the motor in...THANK YOU for your support
Advice needed
flippin heck Damon! 🤐
Give us a chance to help you!
What boat is it, how big, what battery, what prop, what motor, if you can tell us these things, with pics if poss, we can help, you might not even need water cooling, if you cannot provide the info, it really is a question that is far too vague to answer. Have you actually run the boat to discover that things are getting hot, it could just be something amiss with your set up
Advice needed
Opps Alan sorry wrong picture now I could say its in disguise what do you think? lol 😉
Advice needed
Deffo a tug , either way if the drivetrain is well matched you shouldn't need cooling really , just my opinion
Advice needed
Looks a bit like a tug to me, but what do I know 😁
Advice needed
Thanks Alan meant a lot, what I've made is a Corvette from WWII 😀
Piaciuto da DessieB
Advice needed
As you seem to be keeping the boat a secret 🤐 :grin I can only guess.
Run the boat for a little while, then see if the motor is hot, as a rule they don't usually need cooling, depending on set up, but you can get cooling coils for brushed motors if needed.
Piaciuto da ndmb68
Advice needed
What kind of boat do you have ? A prop size and motor make/number would help 😀
A.J
Advice needed
Thanks for your reply Alan, its a brushed motor, then you wont need to blow it up me thinks the hole will sink it quick enough lol ;-)
Advice needed
A bit more information is needed damon, what boat, brushed or brushless motor, batteries, etcetera.
Then we can have a go at blowing your boat your boat up for you 😁
Alan
Advice needed
I've just about finished my first scratch build & when I'll be running my boat do I need to cool the motor? If I do whats the easiest way besides putting a hole at the bottom of the hull? 😰 Thank you 😀
