1:12 Tyne Class Lifeboat
Iniziato da smudger1309
2 replies 0 mi piaces 0 follower Ultima attività: 13 anni fa
I have used Speedline windows on a 1/16 the slipway Trent Lifeboat. Although expensive they are a very accurate product and give a first class result. You might also talk to Adrian at Speedline about the stanchions issue as he may have a solution.
I was going to suggest you look on Mayhem, but see you have already posted and received a reply. Most Lifeboat fittings are best hand made. There are castings available but not that strong and prone to breakage on a working model.
If you are modelling an actual lifeboat then I suggest you check you window suppliers offerings. Not all lifeboats have the same type of windows.
Good luck 😀
I am smudger's dad and have bought him a 1:12 Tyne from Models by Design
To begin with I am looking to source the stanchions (Approx 77mm - mersey class Is the same size)
plus I need the upside down "U" fittings that the stanchions fit on. Any help In the direction of
sourcing these fittings would be appreciated. I do know that Model Slipway do a 1:12 lifeboat Fittings
in white metal but I would prefer brass also Metcalfe Models do not or stock fittings for lifeboats any longer
I can get windows kit from Mac's Mouldings or Speedline Models. Big price difference though
Thank You
Tony Maguire
