Servos going crazy
Servos going crazy
Servos going crazy
As for the varnish I put 2 coats. I used the international and I must say it levels very nicely. Shame it goes off once you open the tin.
Servos going crazy
I decided to use Lipo and power everything through esc. Seems to work fine.
I attached a video as per Colin's request. Cound't upload as the file's too big. Sorry. Dropbox link instead☹️
https://www.dropbox.com/scl/fi/xpqt3w1osba06dvwm4u9o/VID_20240316_165831.mp4?rlkey=cmnd49espyicy6blur6n7g6gf&dl=0
Thanks again guys.
Servos going crazy
Servos going crazy
I sort of interviewed him for an article for International Boat modeler magazine prior to the build review of model.
He was the one who suggested the model was done by Robbe as he had been aboard for a while and had loads of photos.
One of the things was, I asked him how he moved the model around. He said that as the masts dropped down it would all fit into his Clio car!
Was that OK as a reminisce Andy?
Servos going crazy
Firstly, thank you for those words of wisdom, secondly I'd love to show the photos of the set up but since it's Valdivia, everything is hidden by the deck. That's one of the odd things Robbe did. To mount everything on the underside of the deck is borderline insane.
When I put all the pieces together and inside I'll attempt to make a video. Can't however guarantee you'll see everything clearly enough😔
Servos going crazy
Servos going crazy
Huge thanks to all of you for helping me navigate this journey through my discovery of ESC machinations😀
Well, we learn throughout our lives and still die stupid.
Let's then reduce our ignorance more and more every day, shall we?
Just a quick word, my speed controller gives out 6V through bec but in spite of that I had problem with the receiver before removing red wire. Very odd
Servos going crazy
Beautiful piece of design and so nicely balanced.
I have a Futaba 27Mhtz FM 4 ch set as well as 3 off 6ch Micron 27,FM rx.s. Terry used to do kits so these were all home built and worked straight away, needed no tuning.
I also built his very nice 6ch Tx with a centre loaded aerial, got a small fault on it at the moment but as I have all the circuit drawings I can fix it myself. Way back in the days of 16 pin (DILIC) chips and transistors.
Micron now specialize in RC for model railways.
You can't poke a boat with 2.4Ghtz!
Servos going crazy
I picked up the Tx. and started running it very much to the surprise of the guy minding. I think it was a chap called Needham.
I had one as well in the past, mine was bought in Germany in 1958 used it then but proportional came along.
So it was not in use but I took it to work to show to a colleague and overnight someone stole it!
It could only have been our security guards!
Servos going crazy
Good solid bit of kit that still works, now only used for display at vintage shows.
Servos going crazy
They have non-standard servo wiring as the red and black wires are swapped over.
I forgot that once before and wrote off a Fleet Rx.
If you swap them over everything works OK.
regards
Servos going crazy
I decided not to do this to the esc, but used an extension servo lead and simply cut the red wire. Then connected the extension lead between the rx. and esc.
I buy extension leads in 10's from Ali... very cheap!
Servos going crazy
If only using one battery to power everything then ignore the battery socket. Most ESC's give 5 or 6 volts but check the output voltage.
Hope this helps you, cheers Colin.
Servos going crazy
Servos going crazy
My ghast is absolutely flabbered!
Can't imagine what they meant by that as it obviously has a socket for the battery input.
Yours Puzzled, Doug😎
Servos going crazy
I did have one rx with BEC years ago. I can't remember the brand but it was specifically written on the body.
Now I'm really confused😂
Servos going crazy
(You may call me Doug. FLEET is also OK😁)
Glad to help.
Especially with problems with electrical gubbins I do try to explain the full story, to help prevent disappointments or possible production of the 'magic smoke' 🔥😭
Never heard of a receiver with a BEC!
Can't imagine why, or how that would work.
Servos going crazy
Speaking of BEC I thought it's a thing of the past. Receivers used to be marked (or not) as equipped with BEC but nowadays they are not as that feature is no longer being used. I think I read it somewhere.
Servos going crazy
Re "Can anybody confirm is speed controllers send the voltage to reciever? "
Yes most modern ESCs do!
Via an internal circuit called a Battery Eliminator Circuit, BEC.
They do not pass on the full drive battery voltage.
They reduce it to 5 or 6V, with a current usually from 1 to 5Amps. Check the specs of your ESC against the current needed by the servos/winches connected to your RX.
As indicated by the name BEC they are intended to eliminate the need for a separate battery for the receiver (RX). They should not both be connected to the RX at the same time coz they will fight each and may cause damage to the RX or the ESC or both. The kind of instability that you have suffered is also a symptom🤔 Colin was dead right👍
I only use the BEC on 2 or 3 channel boats where the load on the RX is light.
For bigger boats/ships with 6 or more channels for auxiliary equipment; winches, cranes, gun turrets, water pumps, smokers, sound modules etc etc, a separate RX battery is preferable to supply the additional current needed. Then disconnect the BEC by removing the red lead pin of the ESC from the plug and taping it back out of the way.
Hope this helps to 'demystify' things for you.
Servos going crazy
Now with the latest Life and Lipos need to be more careful in my election of battery and servo ratings. To be honest I hadn’t really given it much thought until reading this thread.
Servos going crazy
I have to admit, this is the first time I'm using a motor in a boat.
Servos going crazy
Servos going crazy
Servos going crazy
Servos going crazy
I received an unexpected reply from spectrum. The guy wasn't that helpful but at least I got a reply.
In conclusion it seems like the servos can't be power with more than 6V. One thing the support guy said doesn't make my sleep any better. Apparently the esc sends the voltage to the receiver. Why, oh why since it's being powered by a separate source. Maybe that's why my servos started acting weird after I plugged my esc (powered by 7.2V).
Can anybody confirm is speed controllers send the voltage to reciever? If so how can anybody use Lipo batt with voltage 3.7V (seems low) or the next up- 7.4? That is, to my recent discoveries, way to high for most servos.
Servos going crazy
I have an update for everybody.
After couple of tries I kind of solved the problem. I disconnected the motor controller and switched the 6cells/7.2 batt to 5cells/6V and the problem was gone(it's very odd as I use 7.2v on my other 6V servos with no issues). However after reconnecting the speed controller (with a dedicated 7.2v battery) and playing with the set up for a couple of minutes the other problem occurred. The servos started making ticking noise in equal intervals. I was able to control all the servos but they ALL became very sluggish. I then quickly disconnected the speed controller but it didn't change anything. The receiver was blinking btw, as in every previous scenario.
Do you think connecting another 6V battery directly to the speed controller may solve the problem?
Servos going crazy
But after the tests that are already scheduled, please replace the servo that you normally put on channel 4 with a servo that you are sure works well (even if borrowed from a friend).
If the problem occurs when you insert him, he should be the main suspect.
Servos going crazy
Let's go back to the beginning. The transmitter and receiver are both spectrum and they both came as a set. The sail winch servo on CH1 is analogue the one on CH4 looks like analogue too as it's a cheap one from china. CH2 operates the rudder, CH3 - motor controller. I am using 6 cells Ni-MH pack.
I am going to test my other set from futaba with those 2 servos and see if the problem occurs.
Servos going crazy
I think the problem here is to do with the pulse width - being slightly different - if you are using a servo, let us say from a well known auction site which comes from China - these servos are a bit notorious for glitching because the electronics tend to look for the centre 'off' position, and this causes them to oscillate back and forwards slightly as they are looking for this signal. I have a Hi Tec sail winch servo which does exactly the same thing when I use it on Futaba set-up transmitter and receiver. However, when I use it on the Hi Tec transmitter and receiver it works perfectly. If you have another spare transmitter and receiver of a different make to the one you are using, it may be worth giving it a try to see what happens to see if the servo still glitches.
John
Servos going crazy
I’ve always rung them up first before sending. There details are on the web
Servos going crazy
Servos going crazy
Are all your components Spektrum?
I use some cheaper servos from Soch sails but they are not Digital I gave a friend one who had problems with erratic behavior because he didn't realize it was analogue.
Servos going crazy
I was always taught to start at the battery. What voltage is it? Are you using a BEC to power your radio?
There are many possible causes to your issue.
The transmitter can be too close to the receiver
The main battery could be too low a voltage, say 7.2 lithium, to support the BEC with high current winches/servos.
Bad connections to the servos.
ECT, ect.
The more you can tell us about your set up, the more we can help.
Servos going crazy
They are blue in colour and can drive 3 servos through auto, manual etc.
ESC's for up to about 10 amps, I bought 4 for £14 including postage, and mixers cheap as well. 9 gram servos £1.
They all work and no disappointments.
Servos going crazy
Piaciuto da
Caricamento…
