As Requested for AlessandroSPQR Thesis
Follower (3)
The relationship is only between vessel length and diameter.
The other data, such as: the weight, the number of blades and the material can be useful to those who want to make a choice starting from zero information.
For example, two identical long boats have a different relationship, even if only slightly.
Let's analyze in detail and discover that the one with the larger propeller is heavier.
It is coherent and the reader will have more general guidance.
The type of transmission is one of these non-mandatory data.
If there are any errors, tell me.
https://model-boats.com/forum/135991#135991
Whaw what a Nice collection of boats you Made throughout the years. You can be very proud !!!!!👍
J-502
WEIGHT 0.6350293KG
LENGTH 38.1CM
PROP 2 BLADED NYLON 25MM
MIDWEST LOBSTER YACHT
WEIGHT 2.72155KG
LENGTH 76.2CM
PROP 3 BLADED NYLON 42MM
VILLE CLASS TUGBOAT
WEIGHT 3.53802KG
LENGTH 76.2 CM
PROP 4 BLADED BRASS 45MM
MISS KATHERINE TUGBOAT
WEIGHT 1.54221KG
LENGTH 58.42CM
PROP 3 BLADED BRASS 40MM
ST.PIERRE DORY
WEIGHT 1.632932KG
LENGTH 63.5CM
PROP 2 BLADED NYLON 28MM
VOSPER MTB
WEIGHT 1.451495KG
LENGTH 63.5CM
PROP 3 BLADED NYLON 25MM
Piaciuto da
Caricamento…
