Sea rover cabin cruiser
Follower (16)
- RNinMunichBronze
- mturpin013Bronze
- Commodore-HGold
- zoomaBronze
- jumpuglyGold
Although I almost always do my own art make a stencil and then lightly trace directly onto the transom and then hand paint them.
But, to avoid the “steady hand” game (which I do more and more now that I’m getting older) send your original art to an outfit that will print you a decal.
One consideration is wear or scrapes which can damage the name.
I use various methods and the most common is to make my own decals and apply several coats (at least 5) of clear finish over the lettering.
Florida ⛱️, USA 🇺🇸
Love the picture's of your Sea Rover up on the plane. She looks wicked. Shame about she leaks a bit though.
I have just been and mixed up some good old Cascamite and dribbled
that along the keel of the boat I am building.
But there are plenty of other epoxy resins out her that you can run down the keel to stop the leaks. But she sure looks great oup on the plane.
Looking great to meeting
Turns out these old boats aren’t made from the best materials….. the skin is leaking around the keel ☹️ which means the old circ 1960 ply is now wet inside my new paint. I should have epoxied it .
Florida 💤, USA
Unloaded refers to the rpm of the motor that it is designed to achieve when it is running in fresh air. The manufacturer for instance may state 10k. rpm on 12 volts.
Loaded refers to when the motor is actually being used in a boat etc. The resistance of the water and to a lesser extent losses due to the coupling and bearings mean that less than 10k. rpm will be achieved. 80% is usually used, so that may drop to 8k. rpm.
Obviously using a too big a diameter prop, or one that is very coarse will reduce this further. Hence why I'm thinking that a 40mm prop should be Ok. Better to have a motor spinning freely near its max. design speed than one labouring at a lower rpm and producing heat.
As Boatshed says, trying different props is the way to choose the best one for this boat, but unlike for a race boat, a number of sizes, within reason should work.
I still want to be convinced by the battery being used and until sufficient rpm is achieved you are never going to get decent performance. The basics of the battery and particularly the motor have got to be sorted.
I noticed in your posting: "To plane you want around 9000 - 10000rpm loaded, so around 12000rpm unloaded."
Why would you need more RPM to make a lighter boat achieve the same speed as a loaded boat? Are the numbers reversed? Just curious.
(The intent of this posting was to help solve a lack of speed for the "Sea Rover", and was supposed to suggest the size, type, and pitch of the propeller as inadequate. I'm glad you pointed this out though.)
Thanks',
Florida ☀️😎, USA
From the Prop Shop web-site: "Please note that propeller rotation is based on the British and American standard (viewing the boat from the stern) which is the opposite to that in Germany."
As Graupner are German then that probably explains it?
Yes, That's what I am saying. on the label it says the prop is CW clockwise.
But if you look carefully at the propellor I am sure that it is a CCW Counter-clockwise propellor.
What I was saying is I had been messing about with a couple of my own propellors, as I mainly use CCW ones and the one in the packet looks like a CCW one to me.
I did say I might be wrong but I spent a good 25 minutes going back and forwards turning them back to front before I posted my comment.
Even when you turn a CW back to front it still looks the same as it does the other way and vise versa with a CCW.
To me they are both CCW props, as are about 90% of the ones I own.
I was looking at your picture of your propellor in the packet. I was a bit confused as is has CW on the label. I assume that means it it clock wise. Is that correct. Or am I mistaken, I have been fumbling about with a couple of my own props here by the computer and it looks like CCW to me??
Len
Luckily Chris intervened and confirmed that you want to be even faster and he advised you to increase the number of laps.
He has experience and I am convinced that it is the right advice.
If you also want to work on the size of the propeller, remember that a larger diameter usually requires a more powerful motor than the one you used with the smaller propeller.
For the wheelbase, even if I have no experience, I know that a longer wheelbase (correctly correlated with the number of revolutions) increases the speed (all other conditions being equal), but I have heard from many who then have problems with starting from a standing start or in restarts.
I think you should be alright with a 40mm prop and I think your problem is a lack of revs. 7000rpm is too low and how are you measuring? If unloaded then definitely too low. You don't want to go too big with the prop as you will probably have overheating problems.
Can't find the rpm for your Traxxas motor but I did find one on 24v that only revved to 10000rpm so I'm thinking the 16.8v doesn't rev very high either being as it is a high torque motor for off-road vehicles. Nice motor but I don't think it's suitable for your use.
I can't advise on a motor as I use brushless.
The previous post was to succinctly answer only your question.
For your problem in general I would like to ask you some questions: How do you like the navigation of the RC models of the videos (message nr. 18) of jbkiwi?
Do you want to go faster? Or are you much slower?
I saw some photos of navigation, do you also have some videos to show us?
I ask you this to understand what your navigation expectations are.
If you know the exact point at which the radio control throttle stick does not exceed 12 volts, I don't think you will burn out the motor.
However, it doesn't seem like a good idea to me. I don't see the advantage of setting a higher voltage at the ends of the motor and then being very careful (manually and therefore in an uncertain manner) not to exceed the voltage threshold suitable for that motor.
Now look at the other prop😉 in the photo. That is a 2-3/4 inch prop with a high pitch and much more surface area on the blades. Big difference, and probably more like what you are looking for.
Out of curiosity does the real boat of that design plane?
Florida , USA
I use this combination in my 30" Bates type cabin cruiser, works well with a 2s 2200mah LiPo.
Not sure if you are ok with LiPos. You may have to modify mounts etc (can buy mounts to suit these motors as well.) ESC's not perfect, but a cheap test option.
The motors come in various turns, so you can start with say 34T and see how it goes. If it's too fast or slow, try more T (slower) or fewer T faster. You can play with props as well. These motors are rated at 7.2v but 8v is ok if you don't run flat out all day. you can buy clip on fans and fins for cooling if needed. First vid is with a 45T (too fast) second vid with an 80T.
The result is a poultry speed as you can see.
So it’s back to the drawing board 🙄
I need to find a 775 motor that can spin the 40mm prop much faster on 16.4v and get it on the plane at least.
Any ideas welcome .
you seem to be a little party animal when i see the people on your model boat. What do people say a dirty mind is a joy forever.....😊😊😊
Seems to me that the Sea Rover is no more than a Sea Scout with extended cabin sides and a (IMHO) silly looking pseudo sun canopy.
As such I guess the cabin sides are made of 3mm ply, as in my Sea Scout.
So I used 3mm tinted plexiglass which made it dead easy to fit to the 3mm ply cabin walls
Windows were cut using a scroll saw. They were glued in using Deluxe Materials Canopy Glue. See my Build Blog link below.
Dad built her in the early sixties. I renovated her in 2017/18.
https://model-boats.com/blogs/28209#44511
Those colors look great. Fantastic job👍
The traxxas 775 on 16.4 volts sounds very “tame” so I’m hoping I haven’t got a too low rpm set up . It has a 40mm prop
Game, set, match terrymiff.
I used car striping on my small RAF Crash Tender. I bought some
1/4" white and put that on it, I couldn't paint a straight line and cheated with stripe from Halfords. I done that about 5 years ago. I started building it back in 2015 and and I just stick it to one side , on top of our display unit. The display unit is full of Afghan Hound ornament's, we used to breed Afghan Hounds and show them. My wife doesn't moan about it being up there. But when I bring some other boat in she then say's not another one, You have got a shed to do them in. If you sold some of them off you would be able to work in there. I am still trying to work out the motor for the Crash Tender. I keep swapping from a brushed to a brushless and cannot decide which is the best for it.
I picked this boat up last year very cheap not knowing what I’d do with it.
Its had a long 60-70 year life and at least two different colours being orange then navy - now blue and various engines from ic to electric.
It hasn’t been built to a high standard so I’m having to work with what I have but I’m really happy with the colour - it was nearly bottle green but i changed my mind last minute . I had to build the rear roof as well as replaced the gunwale and installed a chine rail too.
One concern is the bilge has not been water proofed or sealed which can only be accessed by major surgery.
The motor I’ve selected is a traxxas 775 titan swinging a 40”prop . Not sure if I will need 16.8v to get it moving which is what the motor is rated too.
Piaciuto da
Caricamento…
