Large lipo
On brushed motors the current passes through both cables (ESC - motor) in a single direction when moving forward and in the opposite direction when moving in reverse, therefore a single fuse is sufficient to open the circuit.
In brushless motors my reasoning is this: If I put just one fuse on just one cable, in the event of an overcurrent it will open the electrical mesh relating to its winding.
No more current will pass through that winding and the motor stops.
Ok, but what prevents electric current from still circulating in the other windings? In my opinion nothing.
I believe (but I could be wrong) that the control circuit of the brushless motor continues to apply voltages at pre-established time intervals (albeit very short) on the other uninterrupted windings (and therefore in electrical continuity).
By continuing to supply voltages on closed electrical meshes, electric current will still circulate.
Therefore, in my opinion, the crux of the matter is not in the switching speed of the three currents but in the failure to open all three circuits.
If I'm making a mistake, please correct me and explain why.
Large lipo
Only one is used in a brushed motor circuit.
Large lipo
From the nature of the responses received I form the impression that there is a basic need for definitive advice on this topic that can be readily accessible to all modelers. I'm not sure of the best place for this. Any thoughts ?
Having spent a considerable sum on the battery, ESC and motor I feel it best to install the best protection, so I will insert a fuse between battery and ESC, and three fuses between ESC and motor. Fuse ratings will follow advice given, initially using lower rated fuses. As you say, they are cheap enough.
Again, thank you all for your help 😉
Large lipo
Large lipo
In my case the risks are very low as I use good quality ESCs and motors, I don't run my boats hard and our lake is on private land (no rubbish) and the weed is kept well under control, but again as said, why take any risk if for a few £s protection can be easily added?
My only real concern is fire and if I fit a fuse it will be to combat that. I'm glad the wiring has been mentioned as I also think that is the weak link and the fuse should be based on that rather than the motor or other component. The problem for me is sizing the fuse. I use silicone cable from Component Shop and err on the side of safety sizewise but it is the cable fitted by the motor manufacturer that concerns me. If fitted with bullet connecters already and braided as are my Overlander motors it isn't easy to determine the size of the cable but one would hope they are sufficient for the max. current draw of the motor!
I will use car type blade fuses but one thought I do have is that the cable entries use chocolate box type connecters which goes against my use of good quality connectors i.e. XT60 and bullet and is a reason I only want to use the minimum number of fuses.
Large lipo
Sorry if I didn't reply sooner but I had little time and the short pauses were not enough for such a long text.
However, since the first translations didn't seem very comprehensible to me, I shortened many sentences and cut many parts. I hope this is understandable.
Brief answer:
1. Yes.
2. 40A.
3. Yes. Three fuses, one on each cable.
4. 20 Ampere (based on the data you provided).
Complex and reasoned answer (can be ignored and not read by those who consider it useless).
I am absolutely certain about the need to protect the circuit (cables, connectors, motors, ESC, battery), even if many "experts" disagree.
On the positions of the fuses I am quite sure of what I say (very inclined to change my mind if there are concrete elements).
I have no absolute certainties about the amperage thresholds and I am still in the study/learning phase.
During the period in which I participated in the forum I heard interesting advice regarding the correct size of fuses such as that of ColinH. Below I put the relevant links.
Well, I liked both Len1 and Roy, although there are differences between their opinions, not only because I like them and always make very useful interventions but because I agree with their statements, later you will understand why.
First I'll tell you how I did it. From here we can continue with other reasoning.
I used a single 20 Amp fuse, positioned between the brushed motor and the ESC.
At his time, I analyzed the motor's plate data, considered the sections of the cables and carried out practical tests in the tank with an ammeter in series, to measure the electric currents (test in water).
I realize however that I am very conservative (cautious).
I start from the fact that if a person has correctly sized his "electrical system" (from the battery to the engine) he can still risk seeing his ship go up in smoke, even though he has done everything right.
Electrical surges are not a rare occurrence when we are dealing with an electric motor.
Position between ESC and electric motor.
As already mentioned several times (every naval modeller knows this), vegetation, ropes or other material can get caught between the propeller blades and brake or completely block the propeller.
In these cases we will have much higher currents than the operating ones.
This is the most common case to take into consideration.
To overcome this accidental event, simply place a fuse between the ESC and the motor.
For brushed motors, only one is enough because the current flowing on one cable is the same as the current flowing on the other cable.
In your case you need three different fuses (one on each cable) because there are three different currents circulating alternately on the three cables, connected to the respective windings.
The brushless direct current motor normally powers the stator windings to create the rotating magnetic field, which (due to the effect of combined attractions and repulsions) will rotate the permanent magnets.
Size of fuses between ESC and electric motor.
As regards the size of the fuses between the motor and ESC, it is necessary to look at the operating electric current and the maximum current of the electric motor to safeguard the motor, it is necessary to look at the current carrying capacity of the electric cables to safeguard the cables, it is necessary to look at the carrying capacity of the connectors to safeguard the connectors.
I know that many modelers recommend considering the maximum current that the motor can absorb and choosing a fuse with lower amps (For example 5 Amperes less, as ColinH suggested to me). Some say 20% less.
So far I have instead considered the normal nominal operating current of the motor and used a fuse with higher amperes (between double and triple), always taking into account the electric current absorption tests in the tank.
In short, I used a very empirical (very conservative) method.
The first is probably the most correct.
In your case the max load current is 50 A, so 45 or 40 Amp fuses should be fine. However I believe that 45 amp currents can damage your motor in the long run.
In fact, I have found that the best datasheets are those that also indicate the time that a certain electrical device can support certain currents. The operating current is the one that does not create problems even for very long periods of time.
On the other hand, you cannot choose a size that is too small for the fuse, because at start-up the currents are always higher (short-lived peaks).
This is why I don't put instantaneous fuses.
Yours is a fairly expensive motor that needs to be safeguarded.
In any case 40 Amperes would be too many for 16 AWG cables. I agree with Len on this.
You wrote that the capacity is 22 amps (I found even lower values) therefore a 40 amp fuse is suitable for the motor but not for the cables.
However, anyone can ask themselves: Why does the manufacturer put such small cables? Good question. In my opinion precisely because they are sized for the operating current and not for the maximum one.
But I too am waiting for other opinions.
Your engine datasheet is too sparse to make more in-depth considerations.
Fuse between battery and ESC.
The three fuses between the ESC and the electric motor are of no use if there is a short circuit upstream.
For example, if a short circuit occurs between the contacts of the ESC itself, the three downstream fuses (between motor and ESC) will not trip because there will be no electric current passing through them.
It's very difficult for a short to happen there but not impossible. For this reason, even if I didn't put it, I say that it is right to put it for greater safety.
Now the question is: But an upstream fuse (between ESC and battery) protects everything downstream, so what need is there to also put fuses between ESC and motor?
Good question. I'm not sure if my answer is right but I say this:
I'm not sure that the current intensities flowing between the ESC and the motor and between the ESC and the battery are the same.
While waiting for further information and tests which I will carry out when I have time, I believe it is better to protect the two circuits separately.
In any case, if the only fuse upstream of everything (between ESC and battery) is to protect all components, it should actually have a lower cut to also protect the three 16 AWG motor cables.
It is also true that many interruptions are not healthy for the circuit.
In this I agree with Roy.
I prioritize the safety of equipment and cables and use a contact cleaning spray on mobile junctions.
If you install a 20 Amp fuse, first test it in the bathtub at maximum power for a few minutes. If the (car) fuse breaks (but I don't think so) use a larger one (25 A, 30 A).
Here are other very interesting interventions and opinions:
https://model-boats.com/forum/130156
https://model-boats.com/forum/130229
Large lipo
Large lipo
Looking at your diagram, I suggest that you use a 45A fuse at the battery only (the more fuses + more connections that introduce resistance and a failure point).
The Fuse needs to be lower than your 50A max of your motor, (fuses can be fast blow or slow blow.)
I would put in a low Ampere fuse run the boat full throttle in turns as well, and see if it blows, if it does, you need to recover the boat and put a higher value fuse in but still less than 50A.
If it does not blow then your good to go.
You need to protect the component with the least current rating.
Automotive blade fuses and holder are easily available with a choice of ratings.
Regards Roy
Large lipo
I have now put all the information I have onto a sketch, attached, and my questions are:
1. Would you put a fuse between the battery and ESC ?
2. If so , what size ?
3. Would you put 1 or 3 fuses between the ESC and motor ?
4. If so, what size ?
I am very interested to know your thoughts on this subject.
Thanks 😉
Large lipo
Large lipo
You can by Lipo alarms, that plug into the Balance charging connector and monitors all the cells if they become low, it will set off a loud buzzer, they are not expensive.
https://www.amazon.co.uk/Battery-Voltage-Monitor-Checker-Indicator/dp/B0B6N46V5Z/ref=sr_1_1_sspa?crid=28T1J6Q1IBQNM&dib=eyJ2IjoiMSJ9.tjKSXx_T6kL0VDul7ciRB5ARJFjYe9kjNa_McgMhStH2erUenNUwL8MVTiWoPXtbh73bMpjwAPgmWALLDc09V2avd5djXz9nSWseJjKJ_w-oLDc8AxBpdiAc5yRW9-86TWDbk9sbBXx0uCbCu3yujPHpAiwIcmO6oEGK6l94VfvFOGb3OCPEd6Gj-o8LSjxcITUylVGO8-h7K_HBTpRvCEguRbJHV0Iswg94Th_sTA8.BVHKWfZfCbNVR-T_qNKn3wE9oiKo_4YF0Ov6Yn0XYTs&dib_tag=se&keywords=lipo+alarm&qid=1710234929&sprefix=lipo+alarm%2Caps%2C75&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
Large lipo
Can’t see a reason for an active voltmeter, other than to check your nominal battery charge and to avoid over charging.
However, I will defer to the members with more experience with Lopo. 👍
Large lipo
Most importantly is to prevent damage to the motor if something jams the propeller solid, weed, plastic bag. etc this causes the motor to stall and the maximum current will flow possibly damaging the motor and the battery, when this occurs a high current flows producing a large amount of heat very quickly, possibly melting connectors and wiring, even setting fire to the boat!⚡
The max safe current for the motor should be in the motor specifications and the max for the battery will be determined by its 'C' rating times it capacity.
I had a craft that had a 200A ESC and high power motor, I was running on the lake and the thing stopped dead, nothing! I was lucky when I got it to the side a plastic connector had melted (Deans) this was my fault as the connector is only rated at about 50A and my poor soldering didn't help, as any poor joint creates resistance and will heat up.
Regards Roy
Large lipo
I agree with Andy.
Regarding the fuse, I have always supported its usefulness, even in disagreement with many modelers with very long experience.
I think the worst thing that can happen to a model ship is fire.
Worse than the sinking, which is already quite a disaster.
For calibration I got excellent advice from ColinH in other topics.
For the position I placed them between the motor and ESC.
Because I thought that a current surge might occur right there (e.g. aquatic plants or ropes stuck in the propeller).
However, if you also want to put a fuse between the battery and the ESC, it won't hurt.
If strong strains are assumed on any winches and servos I would put it there too.
Large lipo
Piaciuto da
Caricamento…
