Dumas 44 MLB kit 1:16 scale
Oddly enough, in an emergency, I had to break my own vow and walked into a Hobby Lobby and brought some of their CA and was pleased with it. Please don't think less of me...it's just a personal thing I have with them. And for all I know their product may be Bob Smith too as they sell Bob Smith accelerant! LOL!
All in all, it's a toss up between the Bob Smith Industries CA line and the ZAP CA line. Both will serve you well.
However, the Pacer ZAP Z-Poxy two part resins for glassing and coating are without peer in my mind. I don't think Bob Smith does the two part thing.
p.s. If you are concerned about shelf life you can always refrigerate what you don't use, or if there is a long gap between projects...up to two years believe it or not!
As for glue for planking...I use a medium viscosity CA with an accelerator, and sometimes a thin viscosity glue along the seams from the inside.
DUMAS 44' Lifeboat for R/C
https://www.taubmansonline.com/DUMAS 44' Lifeboat for R/C
https://www.rcgroups.com/forums/showthread.php?689096-Building-the-Dumas-U-S-Coast-Guard-44-Lifeboat/page6
https://www.rcgroups.com/forums/showthread.php?920153-Converting-the-DUMAS-44-Lifeboat-for-R-C
https://www.rcgroups.com/forums/showthread.php?689096-Building-the-Dumas-U-S-Coast-Guard-44-Lifeboat/page5
www.mackproductsrc.com
http://https://www.modelshade.com/
"Rotating LED Light for Diecast Vehicles"
https://evandesigns.com/?utm_expid=.DDxFVvGeTZytXUvQWRsOxA.0&utm_referrer=https%3A%2F%2Fwww.bing.com%2F
http://www.44mlb.com/
https://www.rcgroups.com/forums/showthread.php?t=920153
Actual FS 595 color codes with closest matches are:
Hull & superstructure: White FS 17875 (Model Master Insignia White)
Decks: Blue Gray FS 16099 (Model Master Gunship Gray 36118)
Bitts, mast: Spar FS 10371 (Badger Model FLex Marine Deck Tan 16-405)
Boot stripe: Black FS 17038 (Model Master Gloss Black)
CG Stripe: Red FS 12199 (Model Master Chevy Engine Red)
CG Stripe: Blue FS 15182 (Model Master Bright Blue)
I matched color chips of Gunship gray and Chevy engine red to actual colors used on 44' MLB that were in for maintenance at units I served at.
44347 at Station Ft. Point in San Fran
http://www.44mlb.com/model-lifeboats-photos.htm
https://www.44mlb.com/index.html
Build https://www.rcgroups.com/forums/showthread.php?3943597-Dumas-USCG-44-44386
Rebuild https://www.rcgroups.com/forums/showthread.php?2686769-Questions-about-rebuiling-a-Dumas-Coast-Guard-44-MLB
Photo’s https://www.rcgroups.com/forums/thumbgallery.php?t=2686769&do=threadgallery&type=img&group=none&starter=no
Figure https://www.shapeways.com/product/5GSZKB7AD/1-16-uscg-seated-helmsman-3
Use this to cut deck and cabin locations Build log https://www.rcgroups.com/forums/showthread.php?835013-Uscg-Mlb-44
Photos https://www.rcgroups.com/forums/thumbgallery.php?t=835013&do=threadgallery&type=img&group=none&starter=no
44' MOTOR LIFEBOAT OPERATOR'S HANDBOOK
https://media.defense.gov/2019/Nov/14/2002210789/-1/-1/0/44FOOTMLB_CIM_16114_3B.PDF
Stuffing shaft chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://www.shipmodelers.com/uploads/3/4/5/2/34520124/scratchbuildingstuffingboxes.pdf
History
https://www.history.uscg.mil/Browse-by-Topic/Assets/Water/All/Boats-Less-than-65-ft/Article/2016385/boat-44-motor-lifeboat-mlb/
https://www.44mlb.com/boat-info/uscg/44300-44349.html
https://www.crmm.org/
https://www.google.com/search?sca_esv=ad3cebe3ffb4734a&sca_upv=1&q=USCG+44+MLB&sa=X&ved=2ahUKEwj3_biPnYKIAxUKFDQIHb7kCI4Q1QJ6BAg3EAE&biw=2560&bih=1279&dpr=1
Only One whip AM antenna, no fire-fighting station, we just got a hose from the aft lazarette, the engine room vents are square across the bottom the overhead on the cox'n flat was lengthened, and a new break-away mast position. I also recall the emergency tiller arm being stowed inside the aft survivors; I distinctly remember the first rule being tie a line to it before you exit.
Pump placement is starboard side next to tow reel. And, depending on what era you are building, the mast should have the radio freq finder antennas, as well as a small LORAN one. Radar was a bar turning type, not enclosed.
A great reference is the full display at Station Cape Disappointment, lots of pictures. Note the forward rails as well, I believe they are represented wrong on the plans. There is a forum post about someone who obtained a very accurate model of one of these. I used those pictures to help craft my version.
Oh! Also, the splash rails on the hull were changed, there was one all the way around aft as well. That is what comes to mind right now.
I’m looking for any imput an building this kit for RC and to scale. The instructions are not very good and lacking. Any help/input or photo’s would be greatly appreciated.
Thank you in advance
bruce
Piaciuto da
Caricamento…
