Heat Sinks
Heat Sinks
Heat Sinks
Heat Sinks
Florida ⛱️, USA 🇺🇸
Correction (edit): The cutout was a cross shape. Added photos in the order of the repair.
Heat Sinks
Heat Sinks
I checked on ebay.co.uk and did see some Dumas couplings there. There ae some hobby shops in the UK that carry Dumas model boats and accessories, try checking with them. (Photo #1)
Alignment issues - difference between one and teo u-joints. (Photo #2)
Another alternative is getting two u-joints with a short shaft between them. (Photo #3)
About photo #3, that is from the drive set I ripped out of the Krick FLB2 that someone gave me (someday I hope to get back to it). I added the short shaft and new couplings. Photo #4 is an exaggerated misalignment but serves as a guide as to why two u-joints are a vast improvement over a single u-joint. (Also, I did not realize I had any MFA Torpedo 500 motors. Ha!)
Florida 😎, USA ❤️
Heat Sinks
Heat Sinks
I use mainly Microflex couplings and you need to ensure that alignment is accurate - to do this I use a solid coupling of the same length and then replace it with the Microflex coupling. If you use a motor mount that is screwed or bolted into place you will need to shim with washers to maintain the alignment.
Heat Sinks
Heat Sinks
Do you have the ability to measure some voltage and/or current at the motor wires? That is a common setup that I use often (Even the Hobbywing 60 brushed ESC). Different motor brand, but about the same size and I use larger props with no issues.
Florida ❤️, USA ❤️
Have you tried running the motor without he propeller to see if it gest hot?
Heat Sinks
Florida ⛱️, USA 🇺🇸
Heat Sinks
What size prop (pitch as well if you know it)?
Rather than 'treat the symptoms'; i.e. by fiddling with heatsinks, I prefer to find the cause or causes and 'cure' the problem. As Lew and ToraDog have indicated.
Heat Sinks
Heat Sinks
Heat Sinks
First I would look at possible reasons for overheating. Is the motor being driven too hard? (Big prop, free/stiff running shaft, u-joint binding...) Is this a high speed boat? Is the ESC overheating? Does it overheat fast or gradually? Give us more info.
Water cooling isn't too difficult and probably the most efficient.
Florida ⛱️, USA 🇺🇸
Heat Sinks
A simple coil for a water jacket with a pick up aft of the prop should provide more than enough cooling.
Then the is the question of whether or not you may be overloading the the motor with too much pitch and or diameter of prop. Not knowing the application, I can not answer that.
Heat Sinks
Piaciuto da
Caricamento…
