Stanchions, and Railings plastic, brass, or ?
Iniziato da Ronald
10 replies 38 mi piaces Ultima attività: 2 anni fa
First of all this old plastic model kit was bought for $35 and is being altered to represent the Research vessel of 1956 prior to its refit in Montreal. I am not buying parts, just making them as required such as Samson Posts forward of the Bridge. It also needs a winch on the aft deck.
Piaciuto da PemyslJ and Len1
Yes it is possible with 3d printing to do what you want but the resin that I use can be quite brittle and I don't know whether there is anything more flexible that is less likely to snap. Again 3d printing using filament would work but I don't know whether you would get fine enough detail. I buy brass Caldercraft stanchions from Jotika, they may have something that matches what you want.
best wishes Tim
Piaciuto da Len1
Spoken like a master modeler, roycv. Well done
I make my stanchions the same way.👍👍👍👍
Piaciuto da Len1
I am pondering the idea of creating a 3D printed test of a base kick plate, a few stanchions and a single strand running along the top from stanchion to stanchion. Then, use waxed thread or stretch thread tied to each and this will make the remaining cables.
Piaciuto da Len1 and hermank
Stanchions can be a real problem. I bought some soft metal cast ones about 1.5cms high and they were too fragile to be anything but on a static model.
I have in a few cases made my own with 2 brass tubes (for thickness) drilled to take the rail holes. I made me a jig with this close fitting double tube and spaced holes for drilling down and making sure the length and spacing was constant.
These were 2.5cm high and had to meld into taller supports. The tube stanchions had a small length of close fitting wire soldered in at the base and this locates them in the deck all at an even height.
I have some etched brass ones a bit smaller but again very fragile or perhaps it is me! I find with varifocal lenses that I can easily knock things just below the level of my vision.
See picture of simple jig with double tube epoxied into a Vee block. The tube has a small bend in it to grip stanchion tube to stop it rotating when being drilled. The drill is 0.7 mm and just about strong enough for the job. The continuous tube is pushed through measured and then cut.
The rail wire I had to buy in a roll. To make it 'hard' take a length with one end in a vice and clamp the other and hold the clamp and stretch it about half an inch. You then have hard brass wire!
The superstructure just before installation. All rails are soldered in place.
Piaciuto da Len1 and tim morland and
I was at 1:96
If you clip one horizontal layer it could work? I also tried putting brass rod vertical at some points to better support the thin railing. Tom may be able to suggest another vendor. My 3D never worked. The space between rails had filler material. I tried removing it but railing would brake other choice I tried was posts n wire. It’s expensive n a pain Anyway that was my experience enlarge my pic at railing area
Howard hager
Piaciuto da PemyslJ and EdW and
Hi Ron,
David J Parkins (Great Little Ships) does cast and PE stanchions at 4.40 GBP per set.
Plus an awful lot of other deck fittings and bits and pieces.
Happy fiddling😁
https://davidjparkins.com/product-category/great-little-ships/flower-class-corvette-long-forecastle-detail-sets/page/2/
Piaciuto da Len1 and Rookysailor and
I checked Tom’s Modellers website but saw no 1/72nd railings. I sent them an email via the contact page. Waiting for an answer.
Piaciuto da hermank and Len1
I remember some years ago there was a set of etched brass fittings for this kit. Stanchions included.
Piaciuto da hermank and Len1 and
I tried but they didn’t turn out clean. I got railings from Tom model works instead
Howard hager
I am building the flower class 1/72 Matchbox/Revell kit with it many brittle plastic parts, such as the stanchions to represent railings. My question is to those who create 3D parts. Is it possible to create sections of railings from 3D printing that includes the stanchion and the cable railings?
Make a section with a flat base which could be glued to the deck?
