Battery options
Battery options
You will double your running time.
Battery options
before you get too far, I would put all the components into the hull that need to be there. Not installed, just as weight. I would put you hull in a tub and see where she sits reference her waterline. You can go deeper than scale, particularly if your motors will get you onto a plane, as ELCO's usually ran, but be careful. There is not alot of difference between a bit more and getting sunk.
A couple of other thoughts, 1) check around on this site and other model sites. You are not the first to build this model as a RC conversion. Check out how others have done their builds.
2) If you have a RC plane background, try to determine the average flight times for your motors and battery configuration. Mind you that you will be drawing somewhat differently because of two shafts off one battery.
Battery options
Battery options
Honestly, I think that ONE of those motors would be more that enough to power that hull at greater than scale speed. Running one motor will give a long run time and simplify your installation. As long as low speed maneuvering is not too important to you.
Battery options
I have 2 brushless 2838/3800KV with ESC for each. Props are 28mm. (Unsure if U need to know that but trying to give as much info as poss).
I have a few lipo batteries from my plane/drone gear. Is one 2.6 battery enough to power this or should I do 1 battery per side?
There's a lot of info on this but so many opinions its frying my brain! 🤔
All info is gratefully received!👍
Piaciuto da
Caricamento…
