Who has built the Mary Ann?
Iniziato da Ronald
13 replies 58 mi piaces Ultima attività: 1 anno fa
#14 1
Hi Pete5, the last build blog in your email by a member of the Luton club is a work of art beautifully made and finished.
After I saw the actual model I went back to mine and made a better job of it.
Piaciuto da pete5 and hermank and
#13 1
These really help
I hope to get the model in early November after our clubs annual meeting when the person selling the kit and I have arranged to meet up.
Piaciuto da hermank
#12 1
Hi Ronald,
I built Mary Ann recently, as my first build of a scale boat. I also converted her to RC during the build. I think the boat, and the kit, make a great project. The modifications to make it RC weren’t too difficult and it sails well.
As suggested by Roy in an earlier post, I think that resin coating (ideally fibreglassed as well) will make it a much more reliable boat on the water. Early on in the build I found that gaps/splits were easily opened up in the single layer planking, so I put a fine fibreglass coating over the lot and ended up with a very strong hull.
Here are a few links that might be useful…
I posted a detailed build log on the Ships of Scale website...
https://shipsofscale.com/sosforums/threads/mary-ann-by-billing-boats-472-completed.13793/
A Google photos album from Billing…https://photos.google.com/share/AF1QipMJIf0h6SnYPfXfcZ-VHl6UvKgAAkJUX0EvDwMxDjeAWI8YK0rvIOMPffz9SNt9pg?key=ZEdEQWZwMWRzUWg4VWdSTmh3YWJ2OVl4ampING1B
There was also a photo log of a build done by a member of Luton Model Boat club, but it doesn’t appear to be working at the moment… https://lutonmodelboat.co.uk/Building-Mary-Ann.html
Hope that is some use, enjoy your build.
Pete
Regards Pete
Piaciuto da roycv and hermank and
#11 1
Those two examples were German registered shrimp boats that were found to illustrate how the actual vessel design is used in various countries.
Like you said Billings uses the same hull to produce different variations of fishing vessels.
I like your Scottish one you revised
Piaciuto da hermank and roycv and
#10 1
This is not a UK registered boat as the home port registration letters would be bold on the bow and she also has a sharp pointed stern and not rounded as per the Norwegian boat Mary Ann.
Nice picture though I think now stored elseware on my laptop.
My newly restored Scottish western Isles fishing boat hit the water a week or so back.
Piaciuto da hermank and RodC and
#9 1
Just the rigging and masts seem to be different but the hull and wheelhouse appear to be similar.
Piaciuto da RodC and jumpugly and
#8 1
Billing also offer the CUX 87 shrimp boat kit.
This uses exactly the same hull as the Mary Ann. I checked the Billing identification numbers for the printed wood sheets and they are the same.
Piaciuto da jumpugly and peterd and
#7 1
Hi all Mary Ann.
The kit in the picture looks old. The kits currently on sale have the fittings in with them. A test is to check the fittings, if the trawl board arches are brass it is an older kit if they are laser cut wood they are modern and rather fragile.
When building, the deck once inserted in place keeps the hull square but I suggest that a clamped straight edge along the keel should also be used.
However,when keel is cut out the first thing is to discard the propeller shaft in the kit and replace tube and use a narrow one with M4 or 4BA threads and a 35 mm 3 bladed propeller.
Mark the outline of where it is to lay on the keel and cut a doubler of required thickness and stick in place. Then cut the slot for the prop tube in the wood of the keel and fit it and glue it in place, then glue the second doubler over it. I use Marx Luder monoperms but a 385 motor should work as well.
The access for the rudder tiller is under the false stern deck platform which should not be glued in place. I made a brass rudder, set the stock tube in place and have the keel extension screwed in place with a small length of brass tube as a lower bearing.
The rudder can be operated by a 9 gramme servo. The deck opening for batteries, motor and radio are best made before inserting the deck.
You must take into account that the deck has a curve from stern to bow but otherwise flat. The removable section has to have the same curve.
Decide whether you want to detail the wheel house and if you want to have lights etc first so that wires can be inserted.
I use a special shape 6 cell sub-C nimh pack in 2 off 3 cell, side by side units under the main mast, if you use LiPo then some extra ballast is needed. Full speed at 1 amp on 7.2 volts works nicely.
The small unit with visible components is the esc. Around £2 each from Aliexpress they work well, I have a lot of them and never had a failure.
Probably a good idea to use a resin finish on the wood after planking, as in use, as in full size, the planks can spring giving leaks.
Hope that helps.
Piaciuto da peterd and hermank and
Bob
The measurements are 22”x6.5” beam rail to keel 4” according to the fella who is selling it. It was built as a static model but I intend to open up the deck and install a stuffing box, rudder post, then seal it inside and out. $20 CDN comes with the fittings.
Piaciuto da peterd and EdW and
That is a nice little trawler fishing boat.
How long is the model when built?
Piaciuto da hermank and jumpugly
Still remember the box in my shop, it went up with just about everything else I owned (including my beloved Touchwood 1/12th scale Bluebird K-7)in our 2009 house fire. But, most importantly me and the kids weren't hurt. My wife Mary was away. ❤️
And, truth be told, it's been fun slowly replacing everything.
Piaciuto da hermank and Ronald and
One of the first models I ever built, or rather started to build, many many years ago. Completed the hull and some of the upper deck pieces but was really beyond my my skill set at the time lol. Still have the pieces laying around somewhere even after 50 years plus!
Hi I can give you a run down on building the kit, but out this morning. They are lovely models been in production for 68 years!
My harbour has 2.
Piaciuto da Ronald and jumpugly and
Billings has put out several variations of this model. Who has built one? Show us your work. What size of motor did you put in it? Ballast? Any issues with the build?
Piaciuto da jumpugly and sailorboy61 and
