Detachable deck
I used the same small rare-earth magnets that *Ianpat* recommended. For the metal, I used a piece of galvanized hurricane tie, cut it down to the required size and then covered it with a 1/32" sheet of plywood.
The adhesion between the magnets and the galvanized metal is fantastic, and the hatch stays firmly in place while still being easy to remove when access is needed.
Here is a series of pictures showing how I did it, step by step.
Added: My 42 inch Schnellboot boat has multiple ways to get inside. The manufacture's plans showed one massive removable deck section with ugly plastic hold down tabs and screws. Check the photo and you will see the various section openings. (This also makes the hull stronger. Downside is it is a tight access, but several months I managed to do a complete re-build. Battery access is not too bad but I usually do that at home. Power switches are under the pilot house which has a snug (friction) fit.
Another approach if there is some feature that rotates is to make it into a latch so that when it's rotated into the correct orientation, it locks the deck hatch down. I've seen this done with secondary turrets on warships.
I should add that a lot depends on where you run. If you run where careless folks might ram you, then something affirmative like a latch makes a lot more sense than friction. A good impact, knocking the cabin off, can ruin your week. Where I run, collisions are rare and mild, so I don't worry so much about it.
Piaciuto da
Caricamento…
