MYSTERY HULL
Iniziato da Rowen
2 replies 2 mi piaces 0 follower Ultima attività: 11 anni fa
MYSTERY HULL
Thanks Dave,
Am now going to try and run some plans down for the Williamsburg and if successful, plan on building her using that hull.
Will certainly write a blog. However, as I now have several ships to refurbish over winter, along with continuing my HMS Beagle project, doubt will see much progress until later next year.
The Williamsburg was a fine looking ship with a good pedigree and military service Pity her end looks so sad. For other readers who may be interested, there is a history of this vessel on the web.
Piaciuto da Dave M and Northumbrian
MYSTERY HULL
The schooner stern and large rudder suggest a vessel from the first part of the last century.
Construction is bread and butter planks that appear to be laid horizontally. I built a cruiser hull in the 1960's using this construction.
The yacht you suggest is from the 1930', so should make into a nice model. With modern power tools you may be able to clean up the insides and reduce the weight, I know my model was always on the heavy side and I wished I have carved more out of the inside. Withe this type of construction the bulwarks were inevitably added to the hull at a later stage.
Be good to see a build blog as others may have, or come across similar hulls, and could be inspired to do something similar.
Dave 😀
MYSTERY HULL
Was recently given a hull that was found floating on Lake Ontario years ago. Unless somebody can suggest who it could have belonged to, am thinking of using it for a future project.
The exterior is nicely finished, but the interior crude. There is no sheer, it needs building up to the correct height. About 42" long with a breadth of around 7"
Think the mid-body is too short for a liner or cargo vessel, so it looks rather more like a coastal steamer. The only vessel I have found which looks similar is the yacht USS
" Williamsburg".
Would appreciate any other suggestions for a build.
