MV VELARDE
Iniziato da Rowen
5 replies 0 mi piaces Ultima attività: 5 anni fa
MV VELARDE
In Australia Southern Cross Models do a 72 Scale Velarde hull.
Recently a building buddy and I have got a hull each and we have just started. Southern Cross do a set of plans in 72 scale which are quite good. The link for Southern Cross models is https://southerncrossmodels.com.au/index.php
Hope this helps. Also any photos that are available would be welcome as the plans often do not tell the full story.
MV VELARDE
I was hoping that I could get away using it on a 00 1:72 layout but I think it might be to noticeably out of scale. I could possibly try and use it towards the rear and use depth perception. But I think something this grand needs to be a centre piece. That and its very similar to the ships my dad used to go to sea on.
MV VELARDE
Thanks For getting back to me and very helpful. And I will check it out tomorrow
MV VELARDE
Hi Phil.
Did build this model, but finished it as M.V TEAKWOOD. Wrote block on it, but under the Teakwood name. It is still there, just checked.
Would guess the doors are about 1/2" high, do not have ready access to the model to check.
Hope the blog helps
Rowen
MV VELARDE
Hi, did you get the model built in the end? Im keen to know as I was looking at the same boat myself. If you still have it would you be able to measure the accommodation door heights please? Doesn't have to be totally accurate.
Phil
MV VELARDE
Have decided to build this ship as my next project, using a Deans Marine GF hull. Will scratch build from there on.
The are very few details of this ship available on the net, probably because the vessel was built in Germany.
Has anybody else built a model of this ship and have any advise or suggestions before I start to do the planning?
Thanks
