Tamco Tx/Rx
Tamco Tx/Rx
The MFA/Como drills site lists the motor plus a stall current of 11.2amps at 7.2volts max.
I guess you are confirming neither Tx/Rx combination is working.
You have mentioned a new handset, is that a new Tx/Rx?
Hopefully when it arrives you will have a working radio link.
I have used single ESC's with two motors wired in parallel and it will work. Problem is one motor can run faster than the other due to variations within the manufacturing specs.
If you can afford two ESC's you will avoid this.
You can run from one channel using a Y connector lead as Doug has said.
With two ESCs you can run each from a separate battery.
If both have BEC outputs you need to disconnect the red lead on at least one ESC and both if you are using a separate Rx battery as Doug has already explained.
There are mixer units available which link the motors to the rudder setting to help with steering but you do need two ESC's.
If you are an ex flier like myself you can also use two sticks on the TX and control each motor independently.
I do hope you manage to get your model working and on the water soon
Tamco Tx/Rx
John.
Tamco Tx/Rx
John.
John.
Tamco Tx/Rx
I have a 2.4ghz Tamco transmitter and receiver I bought at a bring and buy sale. I have not had any problems with it so far.
John.
John.
Tamco Tx/Rx
Tamco Tx/Rx
Tamco Tx/Rx
Tamco Tx/Rx
Have you managed to test the original Hitek with your rx battery and rudder servo? Does it still work.
If so the ESC is the problem
You can also do the same check on the Tamco TX/RX set.
If neither Rx work then you have probably damaged both.
There are two different motors in your pic with different part nos, please will you confirm what is written on your motors.
Tamco Tx/Rx
You say you bought the boat with the Hitec set-up. Did you ever see it run?
What made you change the RX?
Tamco Tx/Rx
By the way; if you do use an ESC with a BEC and you still want to use a sep. RX battery, to conserve the drive batteries, then you need to remove the RED lead from the ESC plug at the RX. Lift the little plastic tab over the connector and you can pull it out. Fold it back along the cable and insulate it. 😎
Tamco Tx/Rx
Moral: check twice, pay once. We've all done it. I blew up my first Graupner MC-10 TX board cos the battery connector was half hidden and not keyed, and there was no protection diode. There is now! 😎
Tamco Tx/Rx
Some clever bods with 3 hands use separate RX ports and sticks for two motors. I prefer one stick for throttle and rudder.
Each to his own 😎
Tamco Tx/Rx
You can put both ESCs on one RX port by using a 'Y' cable to send the signal to both ESCs. 😎
Tamco Tx/Rx
Can't read the motor type, what are they?
I'm afraid both RX and ESC are probably blown. 🤔
Tamco Tx/Rx
Oops 😲 and both motors on one ESC = double current for the ESC. Doesn't look good I'm afraid.😡 Back to the drawing board - and the bank manager!
Tamco Tx/Rx
Tamco Tx/Rx
@ Dave: the two Dees! We're only missing Dozy, Beaky, Mick and Titch!
Goodnight from Munich 😎
Tamco Tx/Rx
Tamco Tx/Rx
I agree the ESC is toast. Don't plug it into anything.
You should be able to test the Tamco using the RX battery plugged in the correct way. if it is correctly bound the the rudder servo should work in either rx channel. if it does then a new ESC will get you back to working condition.
If you did accidentally reverse the rx battery connection this may have blown both the rx and the ESC.
Lets hope it was just the ESC!!
Tamco Tx/Rx
When you wired up for your test with the old Hitec did at least the rudder servo work?
I note that the Hitec has a BEC, Tamco maybe not! Are you using a separate RX battery? Can you sketch or photograph the boats internal wiring?
Strongly suggest that before you install all the new gear that you do some simple bench tests, without the drive battery!, to check the binding of RX to TX and for example correct servo operation on all the RX outputs.
If you have a spare motor kicking about you could also then test the ESC.
Good luck, let us know how you go on 😎
Tamco Tx/Rx
Tamco Tx/Rx
Tamco Tx/Rx
Sorry I should have explained better. I suspect you may have accidentally reversed the battery plus and minus connections.
Doug has already suggested this and if you did this to the rx the internal BEC would have been destroyed which may account for the smoke. it may also have damaged (melted) the battery lead so check this also. You can buy leads to convert the two pin battery connectors to three pins which will not allow wrong connection. Even if you plug in the wrong way round with 3 pins no damage will be done, just the rx won't have power until you fit the plug the correct way. if your boat works ok with the original rx then the ESC should be ok and it is just the rx that is broken.
You may be a newbie but believe me I and many others have all made the same mistake, sometimes more than once, so you are certainly not alone in that respect.
Tamco Tx/Rx
As far as I can tell both Hitec and Tamco use the same convention with the battery + in the middle. ALMOST the standard these days! BUT, some receivers have the - pin towards the outside of the RX case, some towards the inside. Hitec I'm not sure, Tamco has the - pin towards the outside. See photo. So you need to put the 2 pin batt plug in the outer 2 pins, with RED in the middle.
If you accidentally put the batt on the inner 2 pins and back to front(i.e. black in the middle) you may have blown the receiver!
Can you identify which component (RX, servo, ESC) smoked? And how much smoke was there, a quick puff or lots? From the symptom, screws revving like mad, sounds like you may have had + volts on the signal line and blown the ESC! And probably any other servo connected 🤔
A simple servo tester will tell you if the servos are dead. You can also check the ESC with the tester if you put a little motor on it or a voltmeter.
Good luck 😎
PS I now use Spektrum (DX6) and my older sets were Graupner, Futaba. All still going strong after years of service 😉 Attached are common pin outs for the popular brands.
Tamco Tx/Rx
Tamco Tx/Rx
Different manufacturers use different layouts!
What type was the original RX ??
Tamco Tx/Rx
Tamco Tx/Rx
Tamco Tx/Rx
My guess would be you reversed wired the battery to the ESC. The internal MOSFETs will have cooked and gone short circuit. As you are in a club can a fellow more knowledgeable member have a look and see what's happened?
Tamco Tx/Rx
As for the radio gear, some of my club use Tamco, but i prefer Futaba, FHSS T6, going for about £60 on ebay receivers are about £30 so not cheep but very reliable.
Tamco Tx/Rx
Piaciuto da
Caricamento…
