Varnish
Varnish
Varnish
Varnish
http://www.tonkinois.com/gb_algemeen.htm
Asta luego, Doug 😎
Varnish
http://www.letonkinoisvarnish.uk
They sell it online, and they did have a stand at Warwick a few years ago. Many folk in the classic car and boat trade swear by it. I have a tin in the garage awaiting use on my 46" Huntsman deck after re-planking.
Hope that helps someone, cheers, Dave W 😊
slowing your pace when riding through town
Varnish
Varnish
The Riva is a beautiful boat to work on
Varnish
Varnish
Varnish
Using the wet / washing up liquid technique, BY HAND and with not too much pressure, and a final buffing with a sheepskin pad, I used to achieve finishes on cars you could see your face in 👍 Created a nice little sideline earner for me 😉
I can also strongly recommend spraying (airbrush) several thin coats instead of brushing. This creates an inherently flatter, glossier surface and requires much much less flatting and polishing 😊 Good luck, Doug 😎
Varnish
Varnish
wet with washing up liquid between coats is what creates the polishing effect and final gloss. Something I learned the hard way back in my car restoration days. Dry sanding creates more of a 'silk/satin' or worse matt effect. 😎
Varnish
Varnish
Alan
Varnish
Varnish
Varnish
Try Deluxe materials Ezekote or Clearkote.
Here a possible source in Spain.
Montse Martínez (Samarkanda miniaturaS)
08014 - Barcelona
SPAIN
Tel & Fax: (+34) 93.325.44.24
Email: info@samarkandaminiaturas.com
www.samarkandaminiaturas.com
Radio Control, Miniatures, Plastics and Railway
FEWELL BUSINESS, S.L.
Import & Export
Carretera Comarcal 1413 Km. 35,5
08140 Caldes de Montbui, Barcelona
SPAIN
Tel. +34 938 655 830
Fax.: +34 938 655 340
Email: lourdes@fbsl.es
www.fewellbusiness.com
Good luck, Doug 😎
Varnish
Varnish
Varnish
Piaciuto da
Caricamento…
