1/12 scale fittings
Iniziato da scooter
7 replies 0 mi piaces 0 follower Ultima attività: 16 anni fa
1/12 scale fittings
ive no photos at the moment , if you have a photo of what you require , and some dimensions I may be able to assist you .
1/12 scale fittings
HI Matt
Which fittings do you require. I make quite a few fittings for my 1/12 scale lifeboats so may be able to help.
1/12 scale fittings
hI could you put some photos of your parts that you make as I need some more for my boat.
cheers matt
1/12 scale fittings
re 1/12th scale fittings , I too have had difficulties in finding what I want for my builds , so have resorted to making my own parts from brass , Im currently making ball cleats , Im also looking into the possibility of having them electro plated ! I also make masts, airels and light fittings should anybody else need them fabricating ?
1/12 scale fittings
hI guys yes Dave 1-12scale fittings these are thin on ground. I will try macs mouldings as Griff said I don't have ability to make parts so that is why I would rather buy. I have found some white metal stuff that I might try. is your solent near finished Griff. got any photos. I will keep you both posted.thanks lads for help.
cheers Matt
1/12 scale fittings
HI Matt,
I am also com pleating a Solent class L/Boat. Try macsmouldings.co.uk for items like lifebelts, access doors, radars and other sundry fittings. They are resin cast and have excellent detail.
Good Luck
Griff
1/12 scale fittings
HI Matt
Rather thin on the ground, especially for the Solent model. Model Slipway do some 1/12 scale fittings in white metal and speedline models have some super detail stanchions. The aerials were fairly basic dipoles so I made mine from brass tube and rod, soft soldered where required. I made most of the other fittings from dowel or brass rod/tube but I do have a lathe so turning to shape was possible. if you need to make several bits the same you could try using polyester resin in a silicon mould made from one master - may be useful for the doors / window frames.
Good luck
1/12 scale fittings
hI folks I am trying to restore a solent lifeboat douglas currie the problem Iam having Is finding parts at this scale.
I have bought rail stanchons that are to small and fine rod to fit thats bent when delivred.a mast thats to small the list goes on.can I buy fittings of this size or do model shops give false Info just to make a sale. please If you can help I would like to hear from you.
thanks matt
