Fitting Propshafts
Iniziato da AndyG009
11 replies 9 mi piaces 0 follower Ultima attività: 8 anni fa
Fitting Propshafts
Was just pullin' your chain a little 😁 Sorry🤔
I'll do a quick measure up for the cutter 😉
Fitting Propshafts
Rather than a model of a rope making machine, Doug, this is a machine for making model rope. Always wanted one, in case I ever make that marvellous wooden ship model.
Piaciuto da RNinMunich
Fitting Propshafts
Interesting!
Didn't know there is a market for such models 😁
Fitting Propshafts
I bought one of those bags of gears and got just enough to make a model rope making machine.
Fitting Propshafts
keep it for 7 years and if it doesn't come in handy save it for another 7
Fitting Propshafts
Yep, You just never know when STUFF will come in handy do you?😉
Piaciuto da figtree7nts
Fitting Propshafts
Afternoon Doug,
See, this is why I too. Go around buying different supplies!
"Fair winds calm Seas"
73
Fitting Propshafts
Mornin Ed, 1 to 1. Basically cos that's what I've got in those big nylon cogs. Want to use the nylon ones cos they are wide, so more freedom of movement aligning them, and they should be quieter than metal gears.
Think they came from old printers! Bought a batch of assorted cogs and pulleys at a flea market here years ago. Now they're coming in handy😊
Main purpose is to get the drive down to the propshaft which is mounted very low down in the hull as can be seen in the pics above 😲
Fitting Propshafts
Generally 2 part epoxy unless the hull is made of some strange plastic material. if you have gaps to fill try Milliput ( 2 part epoxy putty).
Fitting Propshafts
Hi Doug,
Is the gearing going to be reduced?
Or it going to be 1 to 1?
3 to 1 would be good, right!
73
Fitting Propshafts
Two part Epoxy Andy 👍
But I prefer to glue the tube rather than the shaft! 😲😁
Piaciuto da NPJ and figtree7nts and
Fitting Propshafts
What do people use to glue propshafts in place ?
