Transfers
Transfers
For me though a can of fixer is still cheaper than a laser printer for the few times I need to print decals, an' I've already got two A4/A3 ink jet jobs any way.
Bon chance to our richer members who have laser printers.
Transfers
My point was and is using an inkjet requires you to seal the printed item before water slide since inkjet ink tends to be water soluble while laser printer ink is not so its one step saved.
obviously once in place on a model it needs to have a protective layer of something.
Transfers
Waterproof? Have you ever tested that?
I'm not so sure, having used them in the office virtually since their inception.
Anyway, when they are mounted on the boat / ship they need sealing in with a coat of clear lacquer or they may sometime 'float' off again.
Apart from that have not yet seen any transfer paper made for Laser printers. Transfer paper made for ink jet printers may melt 😲 in laser printers in the final transfer / fixing unit.
I can tell you, it makes an 'orrible sticky mess wot ain't easy to get rid of. Doug
Transfers
Transfers
You know you can get transfer paper for inkjet printers these days!?
All you need is a PC, inkjet printer and a word processor app, MS Winword or similar. I use the Word Art function in Winword, allows you make curved prints etc.
If you ain't got none o them let me know which names you would like, and size, and I'll make you some. You just need to PM me your postal address. Cheers, Doug 😎
Transfers
Wanted.
Has anyone got any Boat name transfers they could help me out with. Any names would do.
Sid
Piaciuto da
Caricamento…
