New knee, outdoor trials begin.
Iniziato da Colin H
11 replies 8 mi piaces 0 follower Ultima attività: 8 anni fa
Steve, don't be put of by my experiences, mine problem is caused by local health care group not being able to give patients referred by a hospital the aftercare they need. My friend who had the same operation on the same day, but lives in Wales, hasn't had any problems and even gets District nurse visits, to check his condition daily.
So be brave and as long as you can follow the discharge rules then you will be fine.
Piaciuto da RNinMunich and Donnieboy
That doesn't sound good Colin.
I have two knees that are heading towards replacement so was going to ask how long the recovery path was. I don't think I will now as your path has taken a backwards turn. Hope it gets back on track soon.
Steve
Oh yay oh yay! 😡
Hang in there Buddy👍
All the best, Doug
Doug, sounds like a really professional job, I only hope that you get as much enjoyment from the stuff I sent you, I know that you will with the KG V.
Just got back from an epic morning, surgery had screwed up, no qualified staff to remove the staples, had to wait till they located a surgery the other side of the town with a qualified nurse, then nearly an hour in heavy traffic I arrived and still had to wait another 30 minutes till the nurse called me, on removing the dress it was obvious that there was a problem with the operation, it was very inflamed and very hot, the staples were almost hidden by the swelling along the scar site. They had to get a second nurse to assist as they had to dig out the staples, as they came out it started weeping out yellow gunge, extremely painful, and they have had to put me on antibiotics to try and clear it up. They don't think I can have physiotherapy until it is clear. At least the pain is easing now.
Afternoon Doug,
You out did yourself.
On the restoration of Colin's Motor!
"Bravo Zulu"!👍
Cheers, Ed
"Fair winds calm Seas"
73
Piaciuto da Colin H and RNinMunich
OK Colin, Box it is.👍
Just to be on the safe side I'll also bolt an alu heat sink to the rectifier, just as soon as I can find my heat sink paste!!
Viel Erfolg heute, Cheers, Doug 😎
PS and I THANK YOU for the HMS KGV kit and the box of mini motors etc 👍👍
Piaciuto da Colin H and Peejay
Thanks Ed 😊
Here's a reminder of what I started with!! 🤔
Piaciuto da figtree7nts
Morning Doug, thanks for the motor work, I think the box would be best, it looks so much tidyer. Just off to get the staples out, will let you know how it goes today.
Hey Colin, I've got a staple remover 😉 you could nip over here, I'll whip the staples out and you can take the Supermarine back with you! 😁😁
Seriously though folks🤓; Great news Colin, esp. after all this time and pain 👍 Very happy for you 😊
Wasn't kidding about the motor. I'll be updating the 'Resurrection' blog soon.
Attached are a few preview pics of the final tests run at the weekend.
She's chuntering along at 11.1V (equivalent to a 3S LiPo) drawing about 1.3A off load.
I've made up a set of connecting leads and set it up to run ahead with an RH prop as requested. I've assumed your ESC will have bullet connectors!?
FF I've added a Red/Green LED to indicate if it should be running forwards (clockwise) or backwards. BTW: I wouldn't recommend full astern on any more than 7.4/8.6V, she don't like it 😱
Shall I put it in that natty plastic box? Or will you just screw it to a wooden frame? All the best to you both, Cheers, Doug 😎
Hi Colin,
That sounds great! push forward!
I look forward to seeing.
The post of your dad's Sea Commander.
Up and running!
Cheers, Ed
73
Hi fellow boaters, tomorrow is the day I have the staples out on my new knee. And starting Monday at knee clinic, so far so good, movement is good enough to allow me to walk with my crutches, most of the post operation swelling is gone now, a bit of bruising still, only a few painful reminders when I try to stretch or bend it. But should be back modelling very soon. Looking forward to getting my dad's old sea commander ready for the taycol supermarine being restored by Doug in Munich. Well that's all for now folk's,
