soldering
soldering
For a static model I'm not sure why solder is being considered - though it is a good strong way to join brass. Superglue and plastic pipe might be adequate....
soldering
Thinking about things if your using an IC engine and your making a prop shroud then please consider hard ( silver ) solder. Just think about the effect of a failed joint and a rapidly spinning prop. if your joining tubes at app 90 degrees think about drilling the tube your going to join to and fitting a spigot to solder the joining tube to. Making a good mechanical joint is an almost essential requirement for a sound long lasting soldered joint.
soldering
I have found La-co flux (from plumbers merchants) a fabulous "active " flux. La-co spray-on heat mat ( a gel) prevents heat travel away from heated area.
An unsupported butt joint is inherently weak. I would suggest some sort of supporting insert into the tube to maintain the flush appearance,but with added strength.Eg: a smaller close fitting tube of smaller diameter/section.
soldering
For pipework you will need adequate heat. it is hard to get heat out of a contact soldering iron onto a rounded surface. Gas flames are MUCH better at heating pipes.
The small gas torches come with a small pencil flame which is easy to control and direct. Things like this, for instance: https://www.amazon.co.uk/Butane-Micro-Soldering-Welding-Blowlamp/dp/B004U8UALW
Remember that metal conducts heat. if you solder at one end of a tube while the other is in contact with, say, polystyrene foam, then the foam will melt...
soldering
soldering
Joints are expected to be contact joints, not one piece inside another. Would appreciate some feed back, wanting to get started, but not to waste material learning!😉
Piaciuto da
Caricamento…
