Air Sea Rescue Launch 123
Follower (2)
Interesting. But, as far as I can see, these checkers only provide total voltage for NiMH - just like a voltmeter. The individual cell info is just for Lipo or LiFE. Or am I reading their adverts incorrectly?
In fact you'll probably find that most commonly used 'inexpensive' (Chinese🙄) ESCs will only deliver 1 or 2A through the BEC.
Even folks like Action Electronics / Component Shop advise against using them with their modules.
No great demand around here for snow in June❄️
but if you'd like to check back around Christmas time .... 😀
If you are using NiMH or LiPo than I can also heartily recommend a little Capacity Checker/Monitor, available all over fleaBay for a few quid. See attached pic.
The car bulb trick is just to see how the battery reacts to a load.
The Checker can then tell you a bit more, e.g. if you've got a duff cell, which will collapse under load even if the other cells are still good!!
Happy sailing👍 Cheers, Doug 😎
Regards Ian
Reminded me to finish my experiments with Voltage Comparator chips coupled to an external LED ladder or 555 based LED flashing unit as a 'Low Battery' warning!
He he😂 EXACTLY the same thing happened to me with my Sea Scout Ian.
Had to think backwards on her first run😮
Re BEC! That sounds very logical.
The internal regulator will need at least one volt more than the required output voltage (presumably 5V if it's like my 10A Vipers) to work.
Another reason I prefer a separate RX battery 👍
When you check a battery OFF LOAD it will always have recovered a little and show a slightly higher voltage than it would on load!
Check it when loaded with something like an old 5W car bulb and watch the voltage.
At 6V the current will be around 800mA.
The voltage will usually drop a little as the load is applied. But if it keeps on visibly dropping then the battery needs charging.🤔
Your motor will draw much more current of course, which accelerates the process.
All's well that ... 👍
I too like the idea of having a separate battery for the receiver as in the past I have had a main drive battery get extremely low, and by leaving the boat bobbing about in the water for a while it just had enough charge to pulse it in to shore.
If the receiver was run from the BEC then I would not of had the power to do it.
Martin.
She looks very responsive to the helm.
Nice job.
Martin.
I might be tempted to reduce the rudder throw though, seems a little twitchy when you put full rudder on.
What was the snag with the BEC? Never run across that before!
What was it's voltage and current rating?
Trust you disconnected the red wire from ESC to RX after fitting the RX battery 👍
Unless weight is an issue I prefer a separate RX battery anyway, leaving the 'drive' pack to do just the driving😉
Piaciuto da
Caricamento…
