Help needed on outboard for Tom Kat
Follower (2)
As a temp fix when my torque spring failed , I replaced it with a piece of plastic strimmer wire!.
Worked OK ! - Hope this helps !.👍🤞😎
Had thought of converting it using small brass/nylon bevel gears obtained from SHG a few years ago. Probably be easier to use the original type drive which I believe was a normal shaft with a flex cable at the end and a dog drive attached to suit the part on the motor. Problem is I have no idea how the flex cable was attached, how thick it was, how long it was and where do you get the dog coupling from ?
Any suggestions or does anyone have a Tom Kat to measure from ?
Piaciuto da
Caricamento…
