optimist yacht
Iniziato da edd
2 replies 5 mi piaces Ultima attività: 6 anni fa
optimist yacht
Hi Edd, you should be able to sort it from these pics (original 1978 assembly plans for my Optimist- see my harbour,- might pick up the stays from that) which I'm re building. If you want me to PM you, -PM me with email and I can send them to you that way as well (will probably come out larger/ be able to zoom in a bit maybe)
Original had a Graupner winch, but you could substitute a sail servo using the same sheet layout. Sheet tensioner hooked on 'P' is a rubber band. I have replaced the original stays with .020 stainless wire fishing trace (original wound trace rusted and frayed) which will last forever and no holes in fingers.
Piaciuto da edd and Martin555
optimist yacht
She looks a very nice boat, I have found a couple of Youtube offerings of her sailing, you probably have too, but that doesn't really help. My guess would be that the steering servo would be under the stern deck, between the rudder and the cockpit. The sheet servo will be under the cabin top. Hope that helps.
Cheers, Nerys
Piaciuto da Martin555
optimist yacht
hi there guys i have just got hold of a graupner optimist yacht and i am wondering if anyone on here can help me with a few issues i have
1 has anyone got pics of where the servo goes to operate the sails
2 a diagram of the rigging for the mast any help would be much appreciated
edd
Piaciuto da Martin555 and Nerys
