Clyde Puffer Build.
Iniziato da GaryLC
31 replies 77 mi piaces Ultima attività: 6 anni fa
#32
Clyde Puffer Build.
Thanks Mark👍😉
Piaciuto da marky and Martin555
#31
Clyde Puffer Build.
Hi Gary, That's a bit harsh on Doug who puts so much into this site with lots of useful information and keen sense of humour .
Cheers Marky
Piaciuto da Martin555 and RNinMunich
#30
Clyde Puffer Build.
" and then Doug stuck his neb in as he can't help himself. "
Gary? Gary who?
#29
Clyde Puffer Build.
Hi Colin, another useful item from motionco a nice simple gear box with numerous ratio choices.
Piaciuto da Martin555 and Colin H
#28
Clyde Puffer Build.
If l did Martin, it would upset the grandson as well. Hopefully I won't have to worry about it for a few years.🤞
Clyde Puffer Build.
Best Way Colin,
Same as my Myford I didn't intend to part with it but mine was stolen.
Quality machines are hard to find. Unless you want to buy something like a 7 x 10 and spend quite a bit on it to get to a Unimat or Myford level😀
#26
Clyde Puffer Build.
Hi Gary,
As Colin has said Doug (RNinMunich) dose a lot of research for the members of this site saving them time and effort, also the knowledge he freely passes on is also very valuable.
Like other members myself included we try to be as helpful as possible.
Each of us has different strengths and specialties and are able to help other members in those particular areas.
It is because of the good will of the members that has made this site as fantastic as it is.
I like many others hope to be as helpful as possible and to encourage new members in to this very interesting Hobby.
Piaciuto da Ianh and jbkiwi and
Clyde Puffer Build.
Take it with you Colin just to upset him LOL!!
Piaciuto da Colin H and RNinMunich
Clyde Puffer Build.
Good morning Ian, I inherited the unimat from my father, and already my son is trying to get me to give it to him, but I told him that he will have to wait till I'm in me box in the ground.
Piaciuto da RNinMunich and Ianh
Clyde Puffer Build.
Hi Colin, whatever you do don't part with the Unimat!
Piaciuto da Colin H and Martin555
Clyde Puffer Build.
Good morning Gary , yes I have a lathe and mill, also a model makers Unimat lathe and mill.
I will have to see what I need, and try to draw up some kind of plan.
Piaciuto da Martin555 and Ianh
Clyde Puffer Build.
The shafts' bearing's sprockets and chains would be ideal for a paddle steamer, do you have access to a lathe to make bearing housings, small neat ones? As the Motionco bearing mounts are a bit over the top size-wise.
Piaciuto da Martin555 and stevedownunder and
Clyde Puffer Build.
Gary, thanks for the info, and yes doug often researches sites and passes on the links for us to use. I don't have a problem with it as it saves me a lot of time.
I do like what you have done so far and am avidly following your progress.
The shaft and bearing housings are in my thinking for driving a paddle steamer, but electric not steam sadly.
Piaciuto da mturpin013 and Martin555 and
Clyde Puffer Build.
Colin, you asked me a question and I replied, and then Doug stuck his neb in as he can't help himself.
Piaciuto da Colin H
Clyde Puffer Build.
Good to hear you are contemplating a STEAM project in the near future, get yourself a TVR1A BB engine in kit form and build it yourself, a 1/2" bore twin-cylinder slide valve, a very efficient engine which only requires 20 - 30 PSI to run flat out. When you have built it and sorted your valve timing, you'll know everything there is to know about slide valves. A suitable boiler would be a 3 1/2" diameter x 6" length, you can buy a kit of parts and save an absolute fortune, I have seen your silver-soldering. Regards, Gary.
Clyde Puffer Build.
Great job Gary and a very clever solution to a problem many will now benefit from.
I have to say I got side tracked on my steam project because of a sort of commission build and secondly by the dreaded virus, however be assured it is next on the list.
Piaciuto da stevedownunder and Martin555
Clyde Puffer Build.
Hi Colin, and yes of course you can have the name of the supplier of the chains, sprockets, shafts and bearings. It is motionco and they have a lot of interesting gear worth a good coat of looking at, a chain tensioner is not required as just take a link out or add a link when required. The chain is plastic as per the sprockets, but is very very strong, incredibly strong actually. Regards, Gary.
Piaciuto da stevedownunder and Martin555 and
Clyde Puffer Build.
with regard to oil and oiling a steam engine, the steam enters the engine via the lubricator which carries steam oil in the vapour to lubricate the engine internals and moving parts, this is required as model steam engines use an O ring on the pistons, so oil in the cylinder bore is essential to prevent the O rings being shredded. a fine car engine oil is required for crankshaft main and big-end bearings, and all moving joints as per Hackworth linkages and eccentrics etc. The shaft bearings are ball raced sealed for life and the sprockets and chains are of a very hard PLASTIC, although I do admit they look very real so no oil required there.
Clyde Puffer Build.
Can you share the pervayer of the shafts and bearings etc.with us lowly modellers.
I love your solution, and do you have any chain tension adjustment.
Clyde Puffer Build.
Thanks Rick, I appreciate that comment and that's what I had in mind to get the prop shaft to go around the boiler. Then I managed to find a company that made the shafts of either 3 or 4mm diameter plus the bearings and bearing housings, sprockets and chain, basically, everything I needed all from one source at a very reasonable price into the bargain. I have kept the gear ratios at 1 to 1, which could be either geared up or down depending on how it performs on the water. Regards,GLC. (Actually, having solved that problem I seem to have come to a grinding halt on the progress front.) must try harder.
Clyde Puffer Build.
A great start Gary.
For the benefit of the new guys when an engine like this is used do you have to oil every thing including the chains every time you go to use your boat. ?
Piaciuto da Colin H and stevedownunder
Clyde Puffer Build.
I don't know either, but this does happen occasionally, photos seem to just materialise!
Nerys
[Edit] Photos removed martin555.
Clyde Puffer Build.
Hello there, I don't know quite how but some of my photos are on your page, unless you are also building a Puffer with a Cheddar engine???????????????????
Piaciuto da Nerys
Clyde Puffer Build.
As that prop shaft solution is a little confusing hopefully these photos will help.
Piaciuto da mturpin013 and jbkiwi and
Clyde Puffer Build.
That's nice, really appeals to me, a steam driven puffer Will follow this build with interest.
Nerys
Clyde Puffer Build.
My latest building venture is a Clyde Puffer from Mountfleet, which I have made a start on and have managed to sort the somewhat complex problem of running the prop shaft drive around the boiler which is at the back end, with the engine positioned in the middle. As hopefully explained in the attached photographs.
Piaciuto da jbkiwi and Colin H and
