Double Bit Bollard
Iniziato da Ronald
37 replies 62 mi piaces Ultima attività: 6 anni fa
#37
Double Bit Bollard
Mine too Mike👍, for the reasons outlined below.
Piaciuto da Martin555
#35
Double Bit Bollard
"Brass or wood they will look good."
Wood or brass they'll be first class!😁
Go for it Ron👍
If the rudder control rods get in the way; instead of taking the verticals right down to the hull what you could do is;
fit a large strong brass or alu plate (ca 1/8") under the deck section,
make the brass verticals, from rod not tube, with a 3 or 4mm threaded spigot on the end.
Then you can put nyloc nuts with large washer (PS belay washers, fit a single washer-plate connecting the verticals) under the deck to secure it.
Alternatively; drill and thread the vertical for a 3 or 4mm bolt. Preferably 4mm.
Personally I would favour the nyloc nut, but I guess a bolt and permanent Loctite would do the job as well.
But I guess the drill and thread would be easier to do if you don't have at least a simple mini-lathe.
Result, either way: the towing strain is dissipated along the deck.
You just have to make sure that that deck section is well and truly secured!!😉
Just a couple of thunks😉
Piaciuto da Colin H and Martin555
#34
Double Bit Bollard
Go for your own bollard Ron you have the skill.Brass or wood they will look good.
Rick
#33
Double Bit Bollard
I had not thought of using brass to make one. The two uprights would be 3/8” tube and I could use a 1/4” brass rod to make the cross bar. The base brass flat stock.
Martin suggested running the uprights through the deck, and attaching to the hull. The rudder push rods run under the deck under that area, I will look at the best solution.
Count four frames from the aft going forward to locate the placement of the Bollard.
TTFN
#32
Double Bit Bollard
Hi ,not sure what your scale is but I have used spent .22 brass cartridge cases for bollards .
Steve.
#31
Double Bit Bollard
Hi Ron,
I am certain that a man with your skills could make this with ease.
You could even use wood dowels to make it from.
My only suggestion would be is to have the vertical legs protruding through the deck and glued to the hull.
Piaciuto da Colin H
#30
Double Bit Bollard
I tend to agree Colin👍
Especially if Ron intends to get into serious towing.
Competitions maybe?
Piaciuto da Martin555 and Colin H
#29
Double Bit Bollard
We like to try to get to the bottom of things Ron😉
Looking forward to the Sea and Towing Trials of your tug👍
#28
Double Bit Bollard
Good morning Ron,
If it was my tug I would be inclined to make it from brass and silver solder all the joints.
With threaded rod inside the vertical tubes and protruding through the base, this would give a good solid mount.
I hope you intend to attach it to a non removable section so it stays put while towing.
Piaciuto da MouldBuilder and Ronald and
Double Bit Bollard
Hi Pete,
"Evergreen MAY use an export company, but 'Javis' is not one, they are just a wholesale company."
I said they (Evergreen Scale Models) DO use an export company; to export from the US to wholesalers around the world, such as your Javis, and the three in Canada, amongst many others.
On their site you can find the wholesaler(s) in many countries.
If you then go to the wholesaler/distributor site you can find out who the retailers are in your country😊
https://hobby-exporter.com/
The parent company is based in Ohio.
https://www.evergreenplasticsusa.com/about-us
The division that interests us modellers is
https://evergreenscalemodels.com/pages/about-us
In Germany I get my supplies from Krick or Conrad😊
There are also about 8 craft shops dotted around the Munich area who stock it.
Whatever; Happy modelling folks👍
Piaciuto da Ianh and Martin555
#26
Double Bit Bollard
Wow you people really stir things up when an “Officer” asks a question?
Here is my drawing
All Rc parts are installed and working. Minus navigation lights
Piaciuto da Ianh and Martin555 and
Double Bit Bollard
"correct in theory" I think I'm correct in saying that, as you mention, Evergreen MAY use an export company, but 'Javis' is not one, they are just a wholesale company.
Cheers, Pete😊
Double Bit Bollard
Try Model Land and/or PM Hobbycraft; both in Calgary; they will do mail order of Evergreen products; both have a great supply / inventory.
PM Hobbycraft
Address: 2020j 32 Ave NE, Calgary, AB T2E 6T4
Phone: (403) 291-2733
Model Land
Address: 3409A 26 Ave SW, Calgary, AB T3E 0N3
Phone: (403) 249-1661
Piaciuto da Martin555 and RNinMunich
Double Bit Bollard
"correct in theory"
In theory Pete?
Double Bit Bollard
Nerys,
In absolutely no way was I casting any aspersions on Dave Watt.
I was simply pointing out that his site does not use HTTPS security and as such any info, including confidential personal data, sent to him through his site would be open to be read by any 15 year old with the nouse to do a bit of net trawling.
I'm pleased to hear that he does accept PayPal. Otherwise I'd have no way to buy from him.
Personal cheques are unknown here for years.
The last cheque I saw was a company 'Verrechnungsheck' sent to me by an insurance company.
That irritated me cos it cost me €10 to pay it into my account. too much manual 'labour' involved!!😠
They could have simply transferred the money to my account.
ASAP I changed insurers!
Double Bit Bollard
Quite correct in theory Doug, I have an account with Javis in Stockport UK, they used to supply me with evergreen products when I had my shop, and kindly continued my account when I retired, Javis supply most retail shops in the NorthWest with all Evergreen products.😊
Cheers Pete
Double Bit Bollard
" they maybe able to guild you to a retail source!"
Exactly ED👍 That's what I meant.
Evergreen uses an export company and doesn't seem to sell direct to the outlet shops.
Piaciuto da Martin555 and Rookysailor
Double Bit Bollard
I have personally known Mastman for some years, He is a highly respected member of the Association of Model Thames Barge Owners. Builds and successfully races model barges. He produces a wide range of Barge (and other) FG hulls and every possible piece one could want to build a model barge, as well as a wide range of other accessories. I doubt if the model barge world would be as big and active as it is without him. The fact that he only accepts cheques and cash is irrelevant, I personally wish that a lot of other businesses did the same as being a dinosaur I regret this government inspired desire to do away with real money. I must admit, I had forgotten that he accepts Paypal as I always pay by cheque unless I am collecting goods from him, then I pay cash.
Nerys
Piaciuto da Martin555 and MouldBuilder and
Double Bit Bollard
PM Hansen!
Is a distributor for whole sale!
But, they maybe able to guild you to a retail source!
Cheers, Ed
"Fair winds calm Seas"
73
Double Bit Bollard
Trying to find a distributor in Canada of Evergreen products.
Double Bit Bollard
I have just looked at his order form at the bottom of the catalogue and it states that he does accept PayPal.
Just to be on the safe side, I scanned the catalogue and it was clear.
Peter.
Double Bit Bollard
" i trust him and he kept in contact all through transaction"
That's not really the point Jacko.
He may well be the most trustworthy man in the universe.
But hackers and net trawlers are not!
Double Bit Bollard
That's exactly what I was thinking Mike👍
So easy!
Cheers, Doug
Double Bit Bollard
In South Africa all banks are withdrawing cheques at the end of the year. Only way round it is a Cashiers Cheque/Draft. To much forgery.
I pay suppliers by PayPal except a few suppliers in the UK.
Caldercraft/Jotika ain't on of em!☹️☹️
Double Bit Bollard
Not wishing to state the obvious but, Being a modeler can you not very easily make one? Its only a square of styrene card and three pieces of pipe. Evergreen have all the shapes, sizes, sections you could ever need plus the pleasure of doing it yourself and cheaper.
What's not to like, go on have a go
Piaciuto da robbob and Ronald and
Double Bit Bollard
I have used mastman twice payed by bank transfer i trust him and he kept in contact all through transaction
Double Bit Bollard
" Online he only accepts cheques"
Cheques? What are they Nerys?
I haven't seen a Eurocheque for good 20 years!
I'm sure he loses a lot of online trade like that.
Mine for example🤔
If he used PayPal he'd get my business, and others I'm sure, even if he applied the 3% surcharge to cover PayPal's cut.
Piaciuto da Martin555 and Ianh
Double Bit Bollard
I have been dealing with Mastman for years. Online he only accepts cheques, at shows, it's cash or cheque.
Nerys
Double Bit Bollard
WARNING! www.mastman.co.uk.
That web address is not secure folks.😮
So don't send bank or credit card details etc.
Double Bit Bollard
Dave Watts, website is
www.mastman.co.uk.
Mainly bits for Thames Barges, but a lot more besides. Will also make to order.
Nerys
Double Bit Bollard
Dave Watts Mastman does a number of different bollards, might be one to suit your requirements. I think he would make one to your specification if asked.
Nerys
Double Bit Bollard
Hi modellers. Where can I get a Double Cross Bollard for my tugboat that will tow various objects?
The base is roughly 5cm x 6cm. Height of the two main pipes is 6 cm and are 1 cm dia.
I am building 3/4"=1'
If you can open the word doc the drawings are there.
