Sea Commander
Iniziato da PKGreen
23 replies 36 mi piaces Ultima attività: 6 anni fa
Sea Commander
Thank you PK,
Looking at the photos has made it easer, and yes i too would definitely use magnets in this case.
Sea Commander
I mounted a receiver directly to a speaker box with velcro with no ill effects.
Piaciuto da Martin555
Sea Commander
Martin555 asked me for photos of the cabin roof that this enquiry refers to and that’s what I provided.
Thanks for all the help and replies 👍
Sea Commander
Will not be a problem with Magnet application for superstructure
Bill 👍
Sea Commander
Hi Zooma.
Totally agree.
Have used the elastic band from boyhood years and it works well.
Magnets are the modern alternative,and never go ping and are more secure.Also never need to replace them.
Bill 👍
Piaciuto da Martin555 and RNinMunich
Sea Commander
"works well as long as the elastic band is strong enough for the particular application and is replaced before it has time to perish"
... and it doesn't 'PING' off into the lake 😮😠
Piaciuto da Martin555 and Scratchbuilder
Sea Commander
R/C is
AUSTAR AX6S 2.4G 4CH Transmitter Radio Remote Control & Receiver
Sea Commander
Ground testing radios with longer aerials such as the 27meg, and 40/41 meg radio systems should be done with the aerials fully retracted to reduce the effective range before walking way from the model to perform the test.
Some 2.4 gig systems (such as Spectrum) have a range reduction button that can be depressed to give the same range reducing effect.
Pre-arranged hand signals with a "helper" are essential to establish what is going on when the model is too far away to observe the response by eye.
Sea Commander
The elastic band and hook idea has been used for many decades and works well as long as the elastic band is strong enough for the particular application and is replaced before it has time to perish.
Piaciuto da Martin555 and Scratchbuilder and
Sea Commander
No Pk! 😀
Not with today's digital receivers.
In the old days close to analogue tuning coils they might have messed things up a bit, but not nowadays. 😉
On my Sea Scout I used 5mm diameter neodymium magnets to hold down the cabin roof and the aft hatch deck. Haven't lost one yet 😊
Sea Commander
Sorry.
Not sure where the two pictures have come from,but not posted by me.
Bill.
Sea Commander
No adverse reaction to magnets to date using various and different r/c systems.
All of the models have been electric powered and all have used 2.4gig radio systems.
Sea Commander
Hi PK.
I would suggest...Definitely NOT.but
What frequency are you going to run on?
Place the RC as far away from any form of interference as you can under any normal circumstances.
Older RC have much longer aerials which need to be placed much further away from interference.
Newer systems have a short stubby aerial.
Bill
Sea Commander
I agree with Mike.
Magnets in my opinion are by far the best tool.
Whilst the ever faithful elastic band is safe and secure,they can be restrictive.
Bill
Piaciuto da RNinMunich and Martin555
Sea Commander
Hi PK,
Do you have a photo of the Roof/Superstructure that you want to secure ?
It would make it easer to come up with some suggestions.
Sea Commander
Thanks
I did consider that and why not it’s easy to fit and allows easy access
Sea Commander
Hi PK l have a rubber band fitted on the inside of the cover then fitted to a form of hook that is securely attached to the boat itself. stops the cover from lifting and is really easy to lift to gain access to a cabin or a hold May not suit if it needs to be on show but has worked for me.
Piaciuto da Colin H and Martin555
Sea Commander
I fitted one 2mm brass rod to pass through the top of the front windscreen into the base of the front cabin roof.
This worked well, so I repeated this to retain the removable central wheelhouse roof and the rear cabin roof too.
The small bent ends gave me something to pull them back out with when I needed to remove any of the cabin tops, and they were small enough not to be conspicuous.
Sea Commander
Having had a good fitting cabin roof blow off of my Rapier during a high speed run, I fitted some brass rod with small right angled bends on the end to make them easy to push in and pull back out again.
This was a good mechanical fix that never failed, but I have now changed them for recessed magnets that i hope will work as well when I am able to get back to the club lake again this season.
Sea Commander
How do you secure removable ‘roofs’, to stop them being blown off, or lost during operation of the boat
Piaciuto da Martin555 and Colin H
