Advice request regarding Prop dimensions
Iniziato da Allan
15 replies 42 mi piaces Ultima attività: 6 anni fa
You are welcome Allen.
Good luck with the building of the Calderwood Clyde Puffer.
I am looking forward to the build log.
And any time you have a question just shout.
The good members here will help as best they can.
Hi Fred,
Thank you for your input, that's very helpful to know, I'll have a look there. Much appreciated 👍
regards
Allan
Piaciuto da Martin555
Hi Martin, that's very helpful.
Many thanks for this 👍
Allan
Hi Allan,
The video it for real boats but it can still be used to identify your model props.
Hope this helps.
Piaciuto da Scratchbuilder and Allan
Hi Allan
I have nothing to do with this company.
When I have a need for a replacement prop I always go to Prop Shop, Simon is very helpful and has a great knowledge with regards to props.
He is a small company so it may take some time before he answers you questions but he will in time.
Fred
Piaciuto da Allan and Martin555
Thanks everyone, I really appreciate the help and support offered on this site, it is invaluable and very much appreciated.
Kind regards
Allan 👍😊
Piaciuto da Martin555 and Colin H and
Thanks Colin,
Thats good advice which has been noted.. 😊👍
Allan
Hi Roy
Thank you very much for your help & advice which is helpful and much appreciated, 👍
Allan
Thank you, your views/input is very helpful.
Much appreciated
Allan👍
I'm certainly not an expert on the matter and can't provide the marine engineer's explanation of the pro's and con's of outboard vs inboard turning wheels, but can say from experience that in a scale model the inboard turning wheels provide the best looking wake. (Aft looking forward, port turning clockwise, stbd turning counter clockwise.)
I don't know if the better performance of either direction could be determined (that is to say would we notice any difference either way...) on our scale equipment, but my gut feel is in-turning wheels throw the water towards the center creating more of a stern wave.
Piaciuto da Martin555 and RNinMunich and
Hi Colin.
I agree 💯% with that advice having lost as you say expensive props in the past and trying to coax a crippled boat back to the shore. 👍👍
Regards Bill.
Piaciuto da Allan and Colin H and
A very well set question, which Roycv answered very well, just an additional piece of information you may need, is to use a dab of thread lock in the prop as you wouldn't want to lose an expensive prop.
I only mentioned this as it has happened tome when I hit a submerged obstacle.
Piaciuto da RNinMunich and Allan and
Hi, measure the distance beween the tip of the blade and the centre which is the radius then double it to get the diameter, Go for a right hand prop of the same diameter as the white metal one.
Looking from the rear of the boat a RH prop spins clockwise to give forward motion of the boat. If this is not right then reverse the connections to the motor.
The prop shaft will have a thread which is either M4 or 4BA there should be a nut of this same thread and a small washer. You will need a thin spanner of this size.
Fit the washer on first then the nut and screw the prop on afterwards. Then with a spanner gently tighten the nut against the prop and that should lock it in position.
Good luck
Piaciuto da Allan and Martin555 and
For twin prop boat counter rotating screws i believe but wait for some expert advise.
Being a newbie to model boat making and having made a VERY slow start trying to read between the lines of given build instructions with my Calderwood Clyde Puffer kit 🤔, I'm realising just how uniformed i am in regards to skill requirements, experience and model engineering skills.
I'm struggling to get my head around scale of parts. I want to replace the white metal Prop provided with the kit for a brass alternative.
Having had a look on line, i have found similar 3 bladed props, but i am unclear what it means by left / right threaded, I'm guessing for screwing on to the prop shaft and nothing to do with the motor? and I'm unsure how to measure the prop to ensure i get the right size for the scale of the model. I've tried measuring across the blades but that doesn't appear to correlate to what I have found in ads, Any advice / words of wisdom would be Very much appreciated. Thank you in anticipation..
Piaciuto da Martin555 and Scratchbuilder and
