Still No Messages
Follower (4)
- Newby7Bronze
- RookysailorSilver
Still No Messages
Stephen just advised me that the problem is now fixed.
Just tested it with the pic that caused the problem with my post and it woiked 😀, see attached.
I had previously tried to add it to my 'Brass pins' post and got the same error message as you.
So you should be able to complete your post now👍
Curious Stephen; your post had hijacked my pic!!
Still No Messages
The fatal error when you submit posts with attachments has been fixed now. Indeed the newer server software caused this. Seems it's not happy with some elements of code that the previous version used to ignore.
Likes notifications:
All notifications were ones that should have gone out in the past but didn't at the time. To avoid bombardment, I did cancel the remaining 'old' notifications from going out. Of course all new ones will still come through as and when they happen.
Some good news:
Maybe I'm speaking too early here, but it looks like emails are working well at the moment. They're arriving within a minute of the event occurring on the website. Now I've said it, it'll probably all change!
Attempting not to adjust the sails so much today and to leave things be as much as possible 🤞😎
Stephen
Still No Messages
I've informed Stephen and he's looking at it.
May have something to do with a new Server software 🙄
Still No Messages
Fatal error: Uncaught TypeError: Cannot access offset of type string on string in /homepages/28/d580901040/htdocs/hobbyland/sysfiles/ajax/post.php:1375
Stack trace:
#0 {main}
thrown in /homepages/28/d580901040/htdocs/hobbyland/sysfiles/ajax/post.php on line 1375
Still No Messages
Pete, Colin, Most of them were, some going back 3 years or so.
But it does explain why for months I have noticed more Likes on the actual posts on site than I had received Liked Notifications for!
Had been wondering who the 'secret admirer was 😁😂
I trust we have now cleared the backlog and things will return to normal.🤞
Whatever that is 🙄
Still No Messages
Still No Messages
Cheers, Pete
Still No Messages
Thanks Stephen,
Took some time to research and compile that Post.
So I was somewhat dismayed to see that it appeared to have gone wrong!
Still No Messages
Intermingled were a few new Forum and Blog posts 👍
Have just spent about 6 hours sorting them out, still some way to go!!
Still No Messages
Thanks,
Stephen
Still No Messages
I'm trying to fix the domain verification part also, which doesn't help the case.
Stephen
Still No Messages
Thanks for all your hard work, I'm sure you are appreciated by all who use this marvellous ( worlds best) model boat site.
Still No Messages
Ultimately the ship will be more stable once I've stopped meddling with the sails.
Changed:
- Server software updated v7.3 - v8.0 (apparently faster)
- Database capacity doubled (space to grow and also a newer version)
- Emails (still slow as ever and being received as "could not verify model-boats.com actually sent this", increasing the likelihood they'll land in SPAM) - so still working on this part.
Apologies if the site goes offline here and there 😔 if anyone is good with setting up DKIM protocols, let me know 👍
Stephen
Still No Messages
Rick
Still No Messages
Congratulations on your promotion.
Unfortunately we are still having troubles with the email notifications.
Stephen is still on the case and working on this problem as we speak.
Still No Messages
Still No Messages
It appears to me that a lack of notifications generates fewer answers, people do not bother to look through the forum threads if they do not have something, ( a notification) to take them there. Thus the less notifications, the less interest and the less answers.
Nerys
Still No Messages
I ain't got nun since 20:53 (19:53) UK time 🤔
But then the 'Trending Topics' column is also out of synch!
Still (at 01:30 CET, 00:30 UK) lists Rick's message from 6 hours ago as the current post.
Also in Redbaron's thread yep120a Trending Topics still lists Colin's post of 7 hours ago as the latest. Not mine of 16 minutes ago or Rooky's of 2 hours ago. 🤔
Still No Messages
Last time (two weekends ago) the web host (IONOS) blocked the sending of emails from the server directly - this was resolved after a communication with them.
This time (this weekend) there's no explanation from IONOS and they insist to continue sending emails that I must setup a webmail account and link up the SMTP details of that to a new mailer function - all fine, except you're limited to 50 recipients per hour and we have new topics that go out to 300 at a time. I'm trailing an idea to get around this.
This morning the code was updated and notifications did work for a while, but as mentioned, it stopped (this is the only one I'll accept responsibility for! 😋). The code wasn't binning out failed sends, getting itself stuck in an endless loop of trying.
Another code change has just been made and it looks like today's backlog is gradually coming down. So they'll be a few old notifications coming through until it catches up.
Hopefully that'll be the end of it once it's caught up 🤞
Stephen
Still No Messages
Still No Messages
Piaciuto da
Caricamento…
