1st build
Iniziato da Old-duffer
6 replies 16 mi piaces Ultima attività: 6 anni fa
1st build
You've chosen a good model as a starter. Easy to build, looks and performs well. Keep the pics coming , we always like to follow progress.
Nerys
Piaciuto da Martin555 and Scratchbuilder and
1st build
Morning Old Duffer.
Looking good.
Keep at it and we will follow with interest.
Be good in a build blog though.
Re the photos,as Martin said follow the guide for the still shots and all should be ok.
Have a practice uploading into the Photo/Files section below the main Post Text area and see if they appear in the photo section,but don’t post them until your sure your happy they are there.
If they do appear do your write up and post 👍👍
Take care.
Regards Bill.
1st build
I am sure that you are not really, 'the old duffer' but take your time over the build and enjoy doing it. Don't work late into the night when you might be tired, that's when things go wrong. As Martin has said, please do a build blog, it makes the project so much more interesting, and is encouraging in its own way.
Kind regards
Geoff.
Geoff L.
1st build
Hi Old-duffer,
Looks like a great start.
You should put this in the Build log section.
Take a quick look at the 'Quick Site Guide' it tells you how to add photos.
This can be found by looking on the lefthand side of the Home screen under 'This Website'. And in the 'How-To Article' section.
If you need any help then just shout.
Hope this helps.
Piaciuto da Old-duffer and Scratchbuilder
1st build
Hi guys I've decided to bite the bullet and made a start on the Slec fire rescue launch, so far so good, no major problems so far and the instructions are fairly easy to follow so at the moment I'm pretty pleased I guess the hard part is yet to come so I'll keep you informed of my p rogress...
Piaciuto da mistyoptic and Scratchbuilder and
