First Sail of 2021
Iniziato da Fred
8 replies 21 mi piaces Ultima attività: 6 anni fa
First Sail of 2021
Thanks Fred, that's most helpful, if I need anything further I'll let you know.
Piaciuto da Fred and Martin555
First Sail of 2021
Hi Colin H
The photo's of the gearbox and motor, as for the prop from the mid of the boss to the tip of the blade was 18 so if I have got this right that would make it 36.
I all ways take the size of the motor then get a prop just smaller in size.
If you need any more then please ask.
Fred
Piaciuto da Martin555 and Colin H
First Sail of 2021
Thanks Fred, a picture of the motor gearbox would help. Mine originally had a monoperm with attached gearbox but it was rusted solid and so was the propshaft and rudder shaft.
I have replaced the rudder shaft and propshaft so far.
Will try to post pictures this weekend.
First Sail of 2021
Hi Colin H
I will have a look and come back to you ASAP,
I am running her on 6 volt SLA battery, and the motor is connected to a gearbox, I have no idea what the ratio is but will try and count the teeth.
Fred
First Sail of 2021
Hi Fred,
She looks good on the water.
It is great to see things slowly getting back to normal and that you enjoyed your little trip out to club waters.
Piaciuto da Fred
First Sail of 2021
Fred, you've got a winner there, looks good on the water, what motor is in her and what size prop, I only ask as I have a Joffre to repair myself .
Happy tugging, cheers Colin.
First Sail of 2021
Hi One and All
Some time back I posted that I had purchased a Joffre Tug.
All the I did to her to make her ready for sailing, was remake the mast and sort out the electrics, and yesterday (27/05/2021) I took her to my club waters (Swiss Cottage MBC) for her first sail,
Fred
Piaciuto da MouldBuilder and Ronald and
