Levi Corsair 28 powerboat
Iniziato da NigelTailyour
12 replies 26 mi piaces Ultima attività: 5 anni fa
If it helps, I can take the pictures again, but in daylight instead and make sure that they are completely flat.
Let me know if you want me to.
Will
Piaciuto da Martin555
I was going to post and say that I don't think it would be easy to convert a Fairey kit as I thought that there are too many areas that would need alteration and Will's post has confirmed this.
As well as the changes to the stern the bow needs changing as well. In side view the Huntsman 31 would appear to have a similar raked bow but it has a significant flare which the Corsair doesn't and the Huntsman's is very round in plan view . Other Faireys have blunter bows i.e. the Huntress and Huntsman 28 and so aren't suitable. Then there is the superstructure of course though that is the easiest to alter, though the deck camber in greater than the Faireys.
In my view to build a credible model it really needs to be scratch built and Will's drawings would greatly assist with that.
Piaciuto da Martin555 and Colin H and
Nigel, the Fairey Hull is a great start for your planned mods, they handle exceptionally well at speed and are admired all over the world.
Happy modelling, cheers Colin.
Piaciuto da Madwelshman and MouldBuilder and
Hi Nigel,
I do hope you do a Build Log.
It will be interesting to see how you convert the kit.
Hi Nigel,
I think that might be one option as i have spent some time looking around but still unable to fined any Plans/Drawings for the Levi.
The other option is to see if you can get hold of a set of plans for the Fairey huntsman and modify from scratch.
Now that dates you, rocker as in motor biker, or American style dancer.
I was a rocker during the mods and rockers war in the 60's.
I was wondering if I could start with a Fairey kit and taper off the rear. The Levi Corsair slopes down at the back to a taper, just like my hair did when I was a rocker and Bo-Diddly was king
I'm still learning
martin555 yes that is the boat. I spoke with the owner and the original builder Mr. Levi built this one for his son in 1979 and my contact bought it from him. So it has a direct line to the builder. If you want a new one, they make them to order for about €150,000
I'm still learning
I am lucky enough to live in a marina and today an elegant cruiser arrived. It’s a Levi Corsair 28. I would love to build a model of it. Roughly the size and lines of a Fairey Huntsman but built in Italy. Does anyone know of plans or a kit that I could use as a base? It’s very pretty!
I'm still learning
Piaciuto da Scratchbuilder and Martin555
