surface filler
Iniziato da paults
4 replies 1 mi piace Ultima attività: 5 anni fa
surface filler
Thanks for your suggestion, I will check this out.
Terence
surface filler
Thanks Dave, I will look into this.
Terence
surface filler
If they are small imperfections then a tube of Knifing putty filler from a car supplies shop is the best. Use sparingly and when dry sand smooth with 1500 or higher wet and dry paper. You may need to treat larger spots more than once so take your time. A light spray with primer will show any remaining imperfections that may disappear after a further light sanding with wet and dry. Like any painting a good preparation will give the best results and usually takes some time.
surface filler
This may be helpful as a filler before painting
Gelcoat Filler White 200g Tin ideal for all fibreglass boat & caravan repairs
https://www.ebay.co.uk/itm/201996664462?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338785333&toolid=10029&_trkparms=ispr%3D1&amdata=enc%3A1C7QXxwAETBi0_xCczdlA5g35&customid=s%3AGS%3Bgc%3ACjwKCAjwjJmIBhA4EiwAQdCbxqOF2D6EYax86UeNTvH8I18jz_q9taYTRjxrNEO12fXvF4qQaqfSOBoCThsQAvD_BwE
Piaciuto da Rookysailor
surface filler
I have some surface discrepancies on my gel coated pilot cutter hull. I believe there is some kind of product that can be used to rectify this but I don't know what it is.
Can any member suggest a suitable product?
