Dremel 965
https://us.dremel.com/en_US/products/-/show-product/tools/hses-01-cordless-electric-screwdriver
It is quite nice with some feature I really like, such as adjustable torgue setting, and especially a trigger that is activated by simply pushing the tool onto the work. However the real reason I bought it was the slower speed. Much better control for drilling and a nice power screwdriver. It cost around $45 US and recharges via a USB cord from a computer of the supplied transformer.
Dremel 965
Dremel 965
Dremel 965
Dremel 965
https://www.sparetoolparts.co.uk/dremel/dremel-395-f-013-039-5fr-spare-parts-list.html
Dremel 965
Quite true Dave, - not sure what the Dremel is, (125w?) but mine are similar and only 135w (not much more than a big light bulb) so not really for leaning on, (rely on revs not torque to get things done) If it's your switch that's dud, and if this is the switch, buy a sack full for spares.
220v 5 speed just not linear. Cheap enough to just buy one to try.
Dremel 965
Dremel 965
If you can't find parts and yours is definitely 240v, you might be able to do the same thing to preserve it. If ever I do things like this, I make sure there is an RCD in the supply system which will make things safe, (just in case) shouldn't be a problem as they are all double insulated these days. The stator shouldn't be a problem, and if the brushes are ok, it should be all good.
You can check the commutator for shorts between the segments and the rotor shaft as well, but these small motors don't burn often, (unless they are stalled). If you get loads of sparks and electrical 'grinding' noises when wired direct, that might mean it's had it, but an RCD will tell you that anyhow, and cut power before anything happens. If an RCD cuts more than once, bin the drill for safety (after making sure it's not just your supply cord shorting somewhere as Hillro mentioned).
Not sure how you could wire yours direct, as they have an odd plug in switch assy, but there will be a way round it if necessary.
Dremel 965
Dremel 965
Dremel 965
I don’t understand the voltages you have measured.
Graham93
Dremel 965
Dremel 965
Dremel 965
Piaciuto da
Caricamento…
